Sonoran steel 1.2 install problem
Look at the install instructions about the placement of the springs on the shock, I think I remember an important point on that in the instructions.....not sure. If you don't see anything there talk to Steve, he's very helpful.
What your describing is normal when vehicle is supported on jack stands.
If your vehicle is still on the stands put a jack under the lower ball joint and
lift A arm up, upper BJ should move away from spring. I also have the 1.2 lift.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
rushw
07-18-2015 01:46 PM
crashburnoveride
07-10-2015 06:39 AM
Vargntucson
07-04-2015 12:15 PM
12, 2000, 4runner, cost, directions, install, installation, instruction, instructions, pics, setup, sonora, sonoran, sosnoran, steel
