so is it bad?
Old 09-10-2003, 07:24 AM
inamo's Avatar
so is it bad?
If I remember correctly in the manual it says that I have to drive in 4wd for at least 10 miles a month to keep everything oiled. And all I drive on is pavement. Is this bad? Oh and I have a limited edition 1995 sr5 4Runner.
Old 09-10-2003, 07:27 AM
waskillywabbit's Avatar
Re: so is it bad?
Wait for a RAINY DAY(s)!! and then fly through the mudpuddles splashing pedestrians!!!
Seriously, I just put mine in 4WD on rainy days because the pavement will slip then and won't be quite so hard on the system. It also lubes it and I get to run through puddles. Wheeeee!
Brian
Old 09-10-2003, 07:38 AM
AznSky's Avatar
I try to drive mine in 4wd for a few miles every month as well. Except when I do it on pavement, most of the time I just go straight and just slight movement of the wheel left and right back and forth. You don't want to go for a full hard turn or u-turn. That'll be bad.......
Old 09-10-2003, 01:20 PM
az4x4runner's Avatar
Or you could do like me, if you live close enough. I get out into the woods at least 3-5 times per week, hehehe
Old 09-10-2003, 01:29 PM
44Runner's Avatar
Re: so is it bad?
I wouldn't sweat it too much man. But whenever you happen to think about it, and you are on a straight stretch of road, just throw it in for a bit and that should be good enough...
Don't
rub it in dagnabit!
Brian
Old 09-10-2003, 01:39 PM
Re: Don't
Originally posted by waskillywabbit
rub it in dagnabit!
Brian
yeah sorry, I couldn't pass up the opportunity..
if it makes you feel any better, some trails get old after a while. I know this area of the prescott national forest better than the city of prescott itself..
oh it also wastes the small ammount of money that I do make, but hey, what else have I got to spend it on
Old 09-10-2003, 01:56 PM
inamo's Avatar
thanks
just want to post a thank you here for all the great insight
Old 09-10-2003, 02:26 PM
Guest
4RUNR's Avatar
I thought the 4WD high in the 4runner was much closer in the way it works to a straight definition "AWD" rather than "4x4", i.e. it was designed to be driven on dry with no ill effect.
Old 09-10-2003, 02:43 PM
No, I don't think so. 4HI on a 4Runner is not the same as "AWD".
Old 09-10-2003, 04:07 PM
Guest
4RUNR's Avatar
The new multi-mode 4WD feature is actually a full-time all-wheel-drive system with 2WD capability. The all-wheel 4WD mode may be used in normal driving conditions on all types of roads from dry, hard surface roads, such as pavement, to wet, icy or snow-covered roads.
http://www.top4runners.com/ja/runhist3.html
The manual also doesn't mention one bit about driving in 4HI on dry also.
Old 09-10-2003, 07:28 PM
Oh, well I have a 2nd gen, sorry, didn't realize they changed.
Old 09-10-2003, 07:46 PM
Shane's Avatar
All 4runners and trucks prior to "multi-mode" have part time 4wd which is not designed to be used on pavement. The driveline will bind up, severe wear and breakage is possible. Straight line driving is OK, just don't try to turn sharply. If you have trouble shifting back out of 4wd try giving it more or less gas. If you get it bound up so bad that you can hardly move forward, keep the wheel how it is and back up slowly until you can shift out of 4wd.
ghostmoney
01-28-2018 11:42 AM
Blamalam
08-16-2015 12:29 PM
corey519
08-12-2015 11:12 AM
nonstop
7
08-11-2015 09:26 AM
keithporter83
07-18-2015 12:37 PM
Quick Reply: so is it bad?
