Smoke coming from the Steering Wheel - 1999 SR5
Old Feb 13, 2005 | 09:45 PM
TRD 4RNR's Avatar
I got in the truck the other night and headed down the road when all of a sudden this terrible electrical burning smell filled the truck. So I rolled the windows down and pulled off the highway.
I popped the hood and could not find or smell any smoke. I returned to the front seat and smoke was curling out from around the base of the steering wheel.
It more or less went away, but i have not been able to figure out from exactly where or why it was smoking.
Everything seems to be working and no fuses have blown.
Anyone got an ideas for me on where to start?
As always, thanks.
Old Feb 13, 2005 | 09:49 PM
Good Times's Avatar
airbag?
check horn
check all buttons on steering
check all electrical lines
Old Feb 13, 2005 | 09:56 PM
dragon564's Avatar
Have you installed anything in that area recently??? I would start looking there..then may turn sig, wiper cruise cont and airbag all run up the steering wheel as well
Old Feb 14, 2005 | 03:01 AM
pfbmgd's Avatar
Make sure you pull the air bag fuse before playing around the air bag .The last thing you want to have is the air bag to go off when working around it .
Old Feb 14, 2005 | 03:55 AM
Cebby's Avatar
If you had an aftermarket alarm or stereo installed, sometimes the installers don't take enough care when stuffing the extra wires under the dash. There's a chance that there are wires that were against part of the steering shaft under the dash and have worn through the insulation to make contact.
Old Feb 14, 2005 | 05:03 AM
EnolaGaia's Avatar
I second Cebby's point... It's a lot more likely that the smoke came from aftermarket / modified wiring (assuming there is any...) and traveled up through the column (as opposed to originating in the steering wheel itself)...
Old Feb 14, 2005 | 05:26 AM
lee's Avatar
lee
cebby's scenario is exactly what happened in my friend's integra.
Old Feb 14, 2005 | 11:49 AM
TRD 4RNR's Avatar
I had an alarm and stereo installed back in 99. I'll start sniffing around that wiring. Thanks.
Old Feb 14, 2005 | 12:01 PM
Yoter's Avatar
Guest
dood thats a whole lotta wiring.
Old Feb 14, 2005 | 01:12 PM
Good Times's Avatar
I call that a big cluster ˟˟˟˟!
Old Feb 14, 2005 | 02:07 PM
FilthyRich's Avatar
how many alarms are wired to that car???
Old Feb 14, 2005 | 02:16 PM
Yoter's Avatar
Guest
My assumption is that you had him wire the interior and exterior lights, stereo, and power seats up to all go off with the alarm. That is sooooooooo much wiring. Did you unwrap it all or was it stuffed away like that? Dont mean to sound like im a dick im just joking.
Old Feb 14, 2005 | 02:19 PM
96LtdYota's Avatar
be nice blue... be nice
Old Feb 14, 2005 | 03:28 PM
Adam F's Avatar
I guess none of you have ever installed a car alarm? Thats only about half the wires you need to do a full install.
Old Feb 14, 2005 | 03:42 PM
Yoter's Avatar
Guest
Gee I dont know.........that looks like pretty dang thick guaged wiring. And where does the big yellow light mount at? LoL, were all just dummy's.
Old Feb 14, 2005 | 04:16 PM
Bob_98SR5's Avatar
hey mike,
good to see you here. ever get that mustang you were looking for?
i'd say that you'd probably be best off taking off the center console and poking around w/ a flashlight for burnt connections. you probably already figured that out by now
yoter, et al: though mike's post count is low, dont mistake him for a noob. mike's probably one of the first guys to buy a 99 highlander in california and to mod it for off road use. so yes, he's got some "history"
that is all
bob
Old Feb 14, 2005 | 04:30 PM
FilthyRich's Avatar
did you find the source of the problem??? keep us posted. This is definetly a first.
Old Feb 14, 2005 | 05:29 PM
Yoter's Avatar
Guest
Originally Posted by Bob_98SR5
hey mike,
that is all
bob
never called him a "noob".
Old Feb 14, 2005 | 05:46 PM
Bob_98SR5's Avatar
yoter,
when did i say you called him a noob? i said 'dont mistake him for a noob'. big difference
bob
Old Feb 14, 2005 | 05:49 PM
Yoter's Avatar
Guest
yoter,
bob
not going to get into it with you over this. that would be petty. I saw it as you assuming I would mistake him for a "noob". i sent you a PM. It may clarify. Ben
