Smell gas when I'm accelerating
Old 11-10-2005, 08:43 PM
fredtheturd's Avatar
Arrow Smell gas when I'm accelerating
I've got the ol trusty 3VZE in my 90 pickup. I just did the intake mod for replacing the air intakes lines & baffles with the straight piece of pipe & it runs like a champ, but I smell gas when I first take off from a stop. Anyone know what might cause this? Also, when I idle with a hot engine, it idles fine around 800-900 rpm, but when the engines hot & I start it, it barely stays running at 300-400 rpm. Any ideas? Thanks for the advice. -- FRED! ---
Old 11-10-2005, 08:57 PM
EWAYota's Avatar
was the smell there prior too? possibly a fuel line leak?
Old 11-11-2005, 06:04 AM
brandontrek's Avatar
hey fred...i was having the same problem off and on for about 2 months...then one day i pulled my yota out of my driveway and stopped to get something out of the house...when i came back i noticed a nice drip comming from the back of my truck...up above the gas tank there is a section(only about and inch or two long)of hard gas line that is not wrapped with any protective tape(or whatever they use)...so after dropping that(thankfully i had very little gas in the tank) and replacing the rotted out section with a piece of flex pipe...problem solved...
Old 11-11-2005, 06:52 AM
I've checked for leaks many times & all along the fuel system. It doesn't smell like raw gasoline. It almost smells like there's an air or exhaust leak. Could a bad catalytic cause this? Maybe a bad O2 sensor? I also read somewhere on here that the 3VZE's are notorious for running rich.
Old 11-11-2005, 08:05 AM
mine does run a little rich...other than that i have no other ideas for what could be causing this problem...
Old 11-11-2005, 07:32 PM
Keggo's Avatar
I smell gas sometimes. Do a quick diagnostic on the truck to see if it throws any codes. I've wondered how to fix the "richness"... hahahaha.
Old 11-11-2005, 07:46 PM
marko3xl3's Avatar
Please, family oriented forum here.
Old 11-11-2005, 08:53 PM
yotaluver's Avatar
if it iz a gas leak u should fix it really soon kuz they start fires (guess u knew that)
Old 11-12-2005, 11:15 AM
Keggo's Avatar
Sorry... I just can't hold it anymore.
Old 11-12-2005, 01:07 PM
i found out that gas burns really good....the hard way...lol...
Old 11-12-2005, 01:24 PM
kyle_22r's Avatar
could be a leaking injector o-ring or a loose banjo fitting.
Sleaker
08-26-2020 06:03 AM
crammit442
7
11-29-2017 12:30 PM
JustToynAround
08-19-2015 11:46 AM
donovanloj
08-16-2015 10:07 AM
tomczaksdiesel
07-26-2015 10:35 PM
Quick Reply: Smell gas when I'm accelerating
