Smallest Lift Around??
Old 10-04-2007, 06:10 PM
imtheant's Avatar
Odd question I know, but with upgrading from stock tires to 265/75/16 on my 02 sport, I see how a small maybe an inch or so of lift would help with appearance. Cheapest and easiset one to install, any thoughts? Just a 1" BL do the trick?
Old 10-04-2007, 06:42 PM
txrunyota's Avatar
No lift, you're fine.
Old 10-04-2007, 08:01 PM
Sloan's Avatar
wouldn't you scrub terribly since the late 99-02 sit the lowest, i also want the same tires for mine but i always though i needed a lift to fit them better.
Old 10-04-2007, 08:03 PM
ozziesironmanoffroad's Avatar
not terribly, spacers in the front should help. and do a slight bodylift. that will help ya big time. but if it doesnt rub, ur fine. it probably wont.
Old 10-04-2007, 08:13 PM
bob200587's Avatar
I thought 3rd gens came with 265/75s stock......
I can't imagine needing any lift to fit those.
Old 10-04-2007, 08:14 PM
FUZION's Avatar
99 4x4 front and rear coils
or a 1 inch roger brown body lift
i rubbed with my 97 on 265/70/17 32"
Got any pictures, I go to tech too.
Old 10-04-2007, 08:19 PM
Sloan's Avatar
on mine it came with 265/70/16.
Old 10-04-2007, 08:51 PM
olsy1984's Avatar
X2...
Old 10-04-2007, 08:52 PM
BLKNBLU's Avatar
Sure. BL is cheapest, $180 from 4crawler, and I'm a fan of small BLs. (some are completely against) But I would also be tempted by the Sonoran Steel #3 because it's all Toyota also. A bit more spendy though, but I still think that is what I would do because that's the way a 4runner "should be" in the first place.
Old 10-04-2007, 09:09 PM
Henrythewound's Avatar
I have a 2000 4wd and had no rub at full turn w/ 165/75 BFG ATs. Of course that was just around town. I had them put on right before I did my lift.
Old 10-04-2007, 09:14 PM
stormin94's Avatar
Crank up your torsion bars........... JK But seriously, Look into some coil spacers, and a small body lift, like 1 or two inches max. Then you probably will have enough to clear 33's.
Old 10-04-2007, 10:11 PM
bob200587's Avatar
going from ~31's to ~32's
Are the fenders that much tighter on 3rd gens?
Old 10-04-2007, 10:40 PM
89macrunner's Avatar
my dad has 265\75\16 on his 99 4runner and they fit fine with no rubbing.
he doesnt wheel at all though
Old 10-05-2007, 04:41 AM
txrunyota's Avatar
I would have alot of pictures, but my last laptop crashed and i lost everything.
It's a stock 99 with 07 TRD sport wheels from a Tacoma
Old 10-05-2007, 04:55 AM
imtheant's Avatar
I'm going to go ahead and have them mounted and see how much they rub (if at all). I dont need any special tools to install a body lift i assume?
Old 10-05-2007, 05:13 AM
BLKNBLU's Avatar
Not really. A floor jack and some scrap wood. Wrenches. Some penetrating oil if you live in a rusty place. A helper would be nice but I got by without. IIRC there was one nut near the rear wheel well that would have been nice to have the appropriate deep socket. I didn't and had to get by with little itty bitty turns of the wrench. There is a good how to on the 4crawler site.
Old 10-05-2007, 05:29 AM
sirsaechao's Avatar
I'm running 265/75R16 with 16 X 8" Ultras on my 02 Tacoma V6 4X4 and they rub on the inner back plastic top of the mud guard inner screw on turns. I'm looking for a front leveling kit but I can't decide on anything atm. I don't want spacers because no one seems to know the right amount of height I need to install to get the leveling I want. My next option was a coilover kit but they are expensive although adjustable but isn't worry free for more that 4 years tops before needing a rebuild. Any suggestions? Oh no body lift please.
Old 10-05-2007, 06:37 AM
mkgarrison5's Avatar
i have a 02 tacoma 4x4 double cab that came with 245-75-16's.. i also want 265-75-16's but i was told it would rub on an offroad setting.. so i guess i might be stuck with 265-70-16's instead of 75's
Dparr2ndgen
09-08-2015 01:06 PM
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
matthew138
09-03-2015 08:21 AM
Ryall
09-02-2015 06:48 AM
Quick Reply: Smallest Lift Around??
