| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Sluggish starting issues
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe. 1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe. |
#2 (permalink) |
How old are your spark plugs? I replaced mine with NGK and it starts alot faster.
__________________
Nate [/font]Suspension: Tundra TRD Fronts w/ Dual 3/8" "TerraBull" spacers: 2.5",Trekmasters, LC's/OEM LC Shocks: 3.5"... Performance: 4" Deckplate, TrueFlow Air Filter, ISR Mod... Shoes: 285/75/16 Nitto TG's, OEM 16x7 (6 spoke)... Armor: Stubbs Sliders... Exhaust: 18" Magnaflow SIDO, Magnaflow High-Flo Converter, 2.5" and 2.25" piping... Other Necessities: Custom Extendable Panhard Bar, Custom Bumpstop Drop Brackets, 1" Diff Drop... |
#3 (permalink) |
My spark plugs are less than 6 mo old. They are NGK too.
__________________
#4 (permalink) |
--Poor grounds or poor power connections.
--Failing starter --Very low output alternator Can take alternator and starter to parts house and have them tested. Check where battery ground wire goes to engine block. Check the block to chassis ground wire at back of motor. Put a dab of grease at these points when they are reconnected. Could be parasitic drain but unlikely. Tuneup won't help this problem since its inconsistent. |
#5 (permalink) | |
Quote:
Yeah, I don't really see what would be draining the battery... Starter seems like its ok... Almost seems like the alternator isn't putting out the juice anymore. Maybe I'll try bringing it to get tested.
__________________
#6 (permalink) |
FYI if you have a slow crank that wouldn't be spark plugs.
__________________
'98 4Runner Limited White w/ silver flares |
#7 (permalink) |
Check out this http://www.yotatech.com/f123/re-3-4l...ac-pics-92286/ You may need to clean your throttle body.
__________________
1998 4runner |
#8 (permalink) |
I think he is describing a slow crank. The motor is turning over slowly. Not that it is cranking at normal speed but taking a long time to start. So it's not going to be a fuel, air, or spark issue if this is the case.
__________________
#9 (permalink) | |
Quote:
Starter or alternator is my guess so far... Anyone have experience in taking out the starter or alt on the 3.4?
__________________
#10 (permalink) |
there are plenty or write ups on removing the starter for the contact replacement issue. The alternator is pretty easy, and straightfoward. I replaced mine twice and the only problem I had was getting the new one in. The alt was the exact same size as the bracket so it woouldn't go in. I grinded it down just a bit and it slid in perfectly.
__________________
#11 (permalink) | |
Quote:
__________________
#12 (permalink) |
Kinda funny i have been having the same issue sometimes. I am almost positive that it is the alternator. I went on a long drive awhile back and the next day it started like it should, like th battery was fully charged. Needless to say i am harder on the battery/alternator than some people........
So i am replaceing it with this as soon as i get the $$$: http://cgi.ebay.com/ebaymotors/ws/eB...104508284&rd=1 then i just need to get the dual batteries figured out (have NO idea how i am going to do that one yet, all the old writeups pictures are missing...)
__________________
Just call me TA 2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck All the Mods that can be done to 3rd Gens Thread My thoughts on Gun control summed up quite nice: “Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns” |
#13 (permalink) |
what kind of amps do the stock alts throw out from factory? they seem weak to me............... also another thought, check your belts.
__________________
02 Tacoma 4-Dr 4x4 V6 117k miles |
#14 (permalink) |
Well I did a voltage test from the alternator, and its putting out 14 volts, which is normal. And the battery has had a full charge... Sooo, I'm guessing its not the alternator now!!
Looks like the starter. Oh boy.
__________________
#15 (permalink) |
very well could be.. now you can get a new or reman'd starter or you can replace the contacts yourself.. cheaper for the contacts but it takes a few hours bc its a biotch (from what i heard). someone will post a link to the write up on replacing the contacts
__________________
#16 (permalink) |
now in my taco, if it sits for a couple of days without running OR its pretty cold outside it takes it an extra second to crank.. sounds like its weak but it usually fires up.. so i dunno if thats just the nature of the beast or what
__________________
#17 (permalink) |
Yeah, its pretty weird. Because, I know when Ford starters go out, they go "click, click, click, click". This just takes a little while, and in the morning is about 2-3 turns of the key to make it even go.
I think I might get a re-manned one. I mean, aren't there a million different issues that a starter could have? Its a bunch of parts in there. Who knows... hmm.
__________________
#18 (permalink) |
yeah mine isnt that bad. i just turn the key and it takes an extra second to fire when really cold or sitting for a few days
__________________
#19 (permalink) | ||
Quote:
To the topic: It looks like to me your starter is dragging.
__________________
1998 4Runner SR5, Surco Safari rack, diff breather mod, Cobra WXST II CB radio, 31" Winston ATs, clear corner/bumper lens, hitch mount backup lamps, PCV catch can. Quote:
#20 (permalink) | |
Quote:
__________________
#21 (permalink) |
Found this thread while searching... My taco takes a few seconds to start, yet the starter sounds plenty stong and healthy... The engine just turns over a few times before it actually starts. I know that my plugs (NGK) only have like 8,000 miles on them so I don't that is the problem.
The only reason I'm asking what could make this happen is that my friend's 88PU with like 250,00 miles starts almost instantly, and quite frankly its emabarrising. I was going to give the TB and IAC a thourough cleaning this weekend, as I've never cleaned the IAC, and see if that helps. Does anyone have any ideas on what else I could check? What about O2 sensors? I'm pretty sure they could stand to be replaced, as I have like 120,000 miles on my rig...
__________________
"It's okay! It's a Toyota!" -Shane Simonian 2002 TRD(4x4) SR5 XCab Taco. Valentine One - Gray Wired - AEM BruteForce w/ PreFilter - Magnaflow - Uniden PC78Elite - Wilson5000 - PA Speaker - Disabled DRLs - PIAA Xtreme White H4's - Rhino Lined - ARB Bull Bar - Custom Rear Tube Bumper - BudBuild IFS Skidplate - LightForce 240's - OME 882's on 5100's up front - Alcans with 5100's out back - Wheeler's steering and sway bar bushings - MC Shifter seat bushings - |
#22 (permalink) |
couldnt it also be that his oil is too heavy? i know in mine if i use 10w-30 instead of 20w-50, it starts a hell of a lot easier in the mornings. but i dont like 10w-30, so yeah. if its a constant thing, does it whether the engine is cold or warm, i think that would be a fuel pressure problem, if only when its cold i believe its due to a thicker oil....
__________________
The 22r series engines are made from the fires of hell, and will fight tooth and nail to not be sent back. 1988 Toyota P/U 4x4 22re, 1200 miles on the rebuild engine builder .268 cam pioneer CD deck 31x10.50x15 BFG A/T BAJA 100W lights on prerunner bumper KC Daylighters 100W rancho rs5000 MUD IS A VALID PAINT JOB! If not living life to the fullest, why live it? my trucks official buildup thread |
#23 (permalink) |
I have 5W-30, but yeah... my taco starts quicker when it's warm. But seems to be how everything works.
__________________
#24 (permalink) | ||
Quote:
I had to search high and low on google and had to e-mail for custom alternators. I've heard of mralternator, but some other members on here have some bad lucks with them so I'm not so sure.
__________________
#25 (permalink) |
I will look into that, i just know that i badly need a better one. After adding the second battery this one just will not hack it anymore. It is having a hard time as it is.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Starting issues...? | AgRunner06 | 95.5-2004 Tacomas & 96-2002 4Runners | 14 | 03-15-2007 07:36 AM |
| starting issues 89 3.0 | shiftless89 | 86-95 Trucks & 4Runners | 0 | 07-17-2006 03:18 PM |
| Starting issues? HELP! | Kcannaday | Maintenance & Repair Archives | 5 | 06-07-2005 03:17 PM |
| starting issues | mp101v | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 01-08-2005 09:30 AM |
