skid plate woahs.
Old 08-11-2003, 01:31 PM
amorphous's Avatar
skid plate woahs.
hey guys,
i took off my skip plate on saturday when I switch the 4r over to mobil 1 and I have a stripped insert bolt (not my fault!- it the farest one back on the front skip plate piece, where the rear and front connect).....I managed to jury rig it back up with a skinny nut/bolt combo - but is there anyway I can fix the threaded insert?
thanks,
aaron
Old 08-11-2003, 02:38 PM
boss hog's Avatar
go to sears and buy a small tap and die set, that includes a 8mm tap. tap out ruin skid plate nut and rethead 8mm bolts or buy new 8mmx1.25 bolt from pep boys.:pig:
Old 08-11-2003, 02:51 PM
Bob_98SR5's Avatar
Tapping is fun!
Make sure you use plenty of tapping oil. Make very small (under 1/2 turn) turns until you feel the thread "set". Add more oil and then turn again.
If there is such a thing as spray tapping oil, you might need it given the fact that the thread is inverted. Otherwise, try a syringe.
Bob
Old 08-11-2003, 03:01 PM
PoBoy's Avatar
Give up and just SAS. No need for a skid plate then
Old 08-11-2003, 03:33 PM
Sparman's Avatar
Also, if you haven't already, you should rplace the factoy 8mm self-tapping bolts with non-self-tapping 8mm x 1.25 bolts.
I swapped mine very early on and I haven't yet stripped any of the factory threads -
and that's with a rockstomper skid that comes off every 3k for oil changes.
Old 08-12-2003, 05:28 AM
amorphous's Avatar
thanks for the advice....
had a feeling that it was either deal with the 'rigged' set up that I have or tap away.
thanks for the advice guys!
aaron
justdifferentials
Just Differentials
06-13-2022 07:40 PM
kawazx636
10-06-2021 03:03 PM
kawazx636
09-29-2015 08:22 AM
Aaronmarston
09-22-2015 09:39 PM
AlexJet
09-14-2015 09:00 AM
Quick Reply: skid plate woahs.
