Sirius Satellite radio mounting suggestions needed
Originally posted by midiwall
Runner4;
I have the Delphi receiver for XM radio which is about the same shape/size of the Shuttle. I don't have a dedicated picture of where it ended up, but you can see it in this shot:
http://www.midiwall.com/4Runner/dirt..._Reiter_13.jpg
Basically, it's sitting just in front of the transfer case lever.
Runner4;
I have the XM Delphi radio, but that Audiovox radio is basically the same size and shape as mine, so I assume it mounts the same.
I bought an ultimount and mounted it flat on the bottom of the hump under the ashtray.
pics are at http://gallery.zemudaville.com/XMBaby%21
Bill
Bill
Originally posted by SLC Punk
I installed it that way at first. But when I opened my rear hatch all the way, the hatch was pressing on the cable. I was afraid that it would short it out. So that's why I moved it to the front.
Do you have the Terk 3 antenna?
I put them on either side of cable and secured them with a dab of silicone glue.
Now I have no worries, and I prefer this mounting location.
Bill
i'm planning on finding and fabbing a goosneck type mount. so i can move it out of the way when not needed.
btw, i just found www.siriusbackstage.com for my sirius forum needs.
for my xm tuner, that is much simpler since it uses the sony unilink bus and i just mount the sucker back in the amp rack out of the way...
#25
Originally posted by bobzemuda
Based on SLC Punks warning, I went to autozone and found some little rubber feet, bump stops that were just a tad thicker than the cable to my XM.
Bill
Bill
Oh well it works and I don't want to mess with it anymore.
#26
Runner4;
Runner4;
#27
Dayum Mark, you need to clean out your interior!!
