Should i get these 2002 4runner rims
What you think on my 1997 limited white 4runner
http://seattle.craigslist.org/sno/pts/278785440.html
Just a little info. I have a 98 on which I added 16" rims and tires. With the larger rims and tires, I am currently not able to pass smog in CA. Not sure how strict your smog regs are. The larger tires put a bigger load on the engine which causes more emissions. Keep that in mind, and you might want to keep your stock rims and tires in case you have a situation like mine. I am going to have to put the stock rims and tires from my wifes 97 on and see if it will pass smog.
Here is a link on another board where someone had to use smaller tires to pass the smog test. I am just looking for a way to pass right now, my tags are expired!!!!
http://board.marlincrawler.com/index.php?topic=1119.80
As long as you know it's the tire diamater that would affect the emissions not the rim size. There is some truth to the fact the running a smaller tire would make emissions go down but like I said, I'll be curious to see exactly how much. I understand it's is very unpleasant to run around with expired tags (esp in California!)
06-01-2021 01:51 PM
Road Bull
10-10-2015 04:55 PM
rushw
07-18-2015 01:46 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
