setting tdc - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-07-2004, 01:01 PM   #1 (permalink)
setting tdc
I have a carbed 84 w/ a 22r. How do you tell if the engine is on the compression or exhaust stroke without pulling the rocker arm cover off? When putting the head back on the distributor was put on wrong the first time so the car won't idle. I know on my mr2 you look in the oil fill hole and look at the cam lobes.
thanks,
Jakub
Jakub is offline
Old 09-07-2004, 02:32 PM   #2 (permalink)
Plays_with_Toys's Avatar
I imagine you can pull the plug and see if the piston is up top... Scroll down a bit, to "can't start my engine" thread by ScubaSteve, he just had to do the same thing, and I think it was explained in there.
__________________
1987 Xtra Cab (4x4) - (SOLD) 22r, Rancho RS 5000, 15x8 American Racing AR-23s w/ 31x10.5 BFGoodrich A/T's, 2.25" exhaust w/ 23 1/8" glasspack, Explorer Pro Comp Prerunner bar/ Hella 500's
Plays_with_Toys is offline
Old 09-07-2004, 10:43 PM   #3 (permalink)
the_supernerd's Avatar
Try putting your finger over the spark plug hole and turn the engine. If you keep the hole sealed with your finger, you should be able to feel the compression against it on the compressions stroke.
the_supernerd is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Any way of knowing if I'm at TDC? benwahballs 86-95 Trucks & 4Runners 7 02-17-2007 10:11 AM
TDC or not? 4runnerD 86-95 Trucks & 4Runners 14 02-14-2007 09:11 AM
How to find TDC? rcm3 86-95 Trucks & 4Runners 3 07-25-2006 06:25 AM
Setting TDC with valve cover off???? Saint_Berzerker 86-95 Trucks & 4Runners 13 03-26-2006 06:33 PM
setting tdc joe d95 95.5-2004 Tacomas & 96-2002 4Runners 1 03-05-2004 09:28 PM
2009 InternetBrands, Inc.
