YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 01-30-2008, 08:04 AM   #1 (permalink)
Personal Sales Rating: (0)
GOH10 Runner's Avatar
Send a message via AIM to GOH10 Runner
Seafoam in Fuel Tank or Injector Cleaner
I am about to go out and buy some injector cleaner(techron) but someone told me to put a can of seafoam in my tank and it will work better....which one will work better?
__________________
Aaron
03 Silver Limited 4WD w/ XREAS
SOLD: 99 Black 4Runner SR5 4WD aka TJ
SOLD: 98 Anthracite Limited 4WD
98 Land Cruiser
GOH10 Runner is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 01-30-2008, 08:36 AM   #2 (permalink)
weakyota91's Avatar
i havent done this yet but ive heard your suppose to put a half can in your gas tank and the other half in the vaccuum on your intake manifold . Through the vaccuum port that goes to your brake booster
__________________
1991 extended cab
3.0 v6
5" sky manufacturing springs
boomerang front shackles
63" chevies in rear
35x12.5 goodyear mtr's
4:88 gears with trutrac front, locked in rear
warn m8000 w/arb front bumper
marlin crawler rear bumper
flowmaster 40 series
weakyota91 is offline
Old 01-30-2008, 08:40 AM   #3 (permalink)
infiltrator's Avatar
Send a message via AIM to infiltrator
yep, you put a third in the brake booster (its the only hose going to the brake cyllinder aka big black round thing) and then you can just dump the rest in your tank. after you suck it up (not too fast!!!) turn your car off. wait an hour or less and start her back up and watch some smoke.
ive done 2 cars through the bb line. both really gave some smoke at first but nothing later. you may experience the same.
pm me if you need help bud.
__________________
Old Rig: '95 4runner | White | ISR | 193,000mi. | Totalled.
infiltrator is offline
Old 01-30-2008, 09:04 AM   #4 (permalink)
Djlarroc's Avatar
Nice! I bought a can of seafoam on Sat, but haven't done it yet because I hadn't researched here yet. That sounds easy enough. I'll probably do it tonight. I do remember members saying not to put it in the crankcase though. Might do more harm than good.
__________________
'89 4Runner: 22RE 5spd, 4:10s w/202K, 16x8 w/265-75 MT, Diamond headlights, Aisin hubs, Tortis' custom roll on paint job, Home made bikini, 1" Body Lift, 1.25" greasable lift shackles, TG Sliders, 1.5" BJ spacers, Rust is gone! - SOLD!
'00 4Runner: ARB F/R, 2" OME, 4:56, 285/75/16, Warn 10K - SOLD!
Djlarroc is offline
Old 01-30-2008, 09:07 AM   #5 (permalink)
X-AWDriver's Avatar
BGs 44K in the tank once a year for me and with good results.
__________________
'99 4Runner Highlander 4wd
E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs
Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub
X-AWDriver is offline
Old 01-30-2008, 09:13 AM   #6 (permalink)
Yodaforce's Avatar
Hold your thumb over the vacume line so the engine doesn't try to shut off, DRIBBLE the Sea foam in until the engine sounds like it's about to die, but don't let it, it can be hard to start if you do that. As you are doing this, you will see smoke out the tail. When you are done with half a can, let go of the vac hose and let the engine die. Then let sit for about 15 minutes, fire up, rev a little. Dump remainder in tank. Done. I used to do this all the time while manging an Express lube joint except we had a special can to inject it with a valve to regulate the amount going in instead of using our thumb.
__________________
"Diverse-Customs" Hot Rods, Street Rods, Custom audio and video installation, sheet metal fabrication, tube work, bumpers, lift kits, just about any kind of custom work imaginable!
Visit us at Diverse-Customs.com
Yodaforce is offline
Old 01-30-2008, 09:33 AM   #7 (permalink)
yeah, i held my thumb and i felt the skin sucking in, it was nasty haha. if i were you i would just use some plyers and squeeze it.
x2 you need 2 people to do this, one to keep the engine alive keeping the rev's up and the other to pour it in.
__________________
Old 01-30-2008, 09:33 AM   #8 (permalink)
Djlarroc's Avatar
Quote:
So YOU don't put it in the brake booster? That's where I was planning o using it. What about 1/3 in the booster, 1/3 in the vacuum line & 1/3 in the tank?
__________________
Djlarroc is offline
Old 01-30-2008, 09:40 AM   #9 (permalink)
you can only put seafoam in a vaccuum line. the brake booster has a vacuum to it, thats why when you pull it, your engine will feel like its going to die with a very rough idle.
either you put it in the brake booster (heard thats safer) or the pcv line both have vacuum. put 1/3 in there, and just dump the rest in about half tank of gas.
the time i did it to my runner i didnt realize it put half the can in my bb line and i was freaking out, but its fine. its hard to see how much.
ive heard people doing anything from waiting 5 minutes to leaving it overnight. i wait an hour and seems to be fine.
__________________
Old 01-30-2008, 09:50 AM   #10 (permalink)
ninjarunner's Avatar
I poured mine in the PCV line, the throttle for the engine is right by your hand sou you can rev it up and while your pouring it it will keep the motor from stalling.
__________________
99' 4Runner - Silver - With ECT button
Custom 6in lift, 315/75/16
Supercharged with URD fuel upgrades and smaller pulley
ninjarunner is offline
Old 01-30-2008, 10:10 AM   #11 (permalink)
j-man's Avatar
Quote:
i use 1/2 bottle in pcv, 1/2 bottle in engine, 1 or 2 bottles in gas tank. That will clean out anything and everything in your car.
__________________
01 tacoma-sold, 98,99,2000 4runners sold
06 tundra 4x4 v8....soon to be built up...
2003 Landcruiser 285 BFG At's and outback roofrack
My Baja Trailer Build: http://forum.ih8mud.com/showthread.php?t=179520
www.samsonfab.com
j-man is offline
Old 01-30-2008, 10:22 AM   #12 (permalink)
Threadstarter [OP]
I can't run it through the vacuum because I don't want to have to replace the oil and plugs cause they are both fairly new....im just looking to do some injector cleaning.
__________________
Aaron
98 Land Cruiser
Old 01-30-2008, 11:44 AM   #13 (permalink)
mkgarrison5's Avatar
guys 1/2 bottle in the tank aint sheeit!!! what a waste. here is what i do per MTL
1st 2-3 bottles per half a tank or less and run empty
2nd 1 full bottle thru the pcv valve BUT do it in 1/3 increments letting each increment sit for as long as possible. one little tip, do not turn the motor off until you see the smoke starting to poor out then let her sit. the longer the better
you guys that do half a bottle via the pcv and the other half in the tank is such a waste, if you think you feel a difference with that little mess then do it the right way.
__________________
02 Tacoma 4-Dr 4x4 V6
117k miles
mkgarrison5 is offline
Old 01-30-2008, 11:46 AM   #14 (permalink)
btw dont put anything in your motor unless its motor oil!!!
also, when i do this seafoam treatment i do it RIGHT before an oil change and plus i change my plugs. which means i do this every 30k miles
__________________
117k miles
Yotatech
4WD Truck
Paid Advertisement
Tags
car, cleaner, foam, fuel, gas, injection, injector, put, rust, sea, seafoam, system, tank, treatment, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Seafoam Injector / Intake Cleaner = GOOD STUFF bamachem General Vehicle Related Topics (Non Year Related) 601 02-21-2011 07:33 PM
Fuel Injector Cleaner Paul H. General Vehicle Related Topics (Non Year Related) 31 04-18-2010 07:23 PM
What's the best fuel injector cleaner? AgRunner06 Maintenance & Repair Archives 61 06-14-2004 06:51 AM
fuel injector cleaner 3.4v6 Off Topic Talk 2 11-20-2003 05:56 AM
What fuel injector cleaner to use? Dr. Evil 95.5-2004 Tacomas & 96-2002 4Runners 28 07-19-2003 09:03 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
