Sea foam visual challenge
Old 02-21-2006, 01:10 AM
914runner's Avatar
Originally Posted by jeremys73
weLLLL Bamachem, I think you should know better.... There was actually a guy that posted in Bamachem's super big Seafoam thread that took off the heads. He didn't actually take pics of the top of the valves but did take pics of the cylinders and pistons. I have no idea what page that is on, you'll have to take a day and read it yourself. https://www.yotatech.com/forums/f123/seafoam-injector-intake-cleaner-good-stuff-64836/
But hey, stay on topic now! Were talking about the valves here, not the pistons!
msw0085's Avatar
Originally Posted by CoedNaked
So....back on topic.
Has anyone considered inspecting the results of Sea Foam? The reason I ask is for the guys who do NOT want to remove their heads to clean their intake valves, etc.. Hence they don't want to use water, or transmisison fluid, or any other noted miracle cures because again, their heads won't be off. If we all took our heads off and cleaned our intakes with the above mentioned techniques, we woudln't be talking about Sea foam now would we? That is the GOAL - to find out the results of Sea Foam, before, and AFTER it is used by inspecting the valves with the heads of, before, and after.
Pardon my sarcasm but this is the second time I've intervened in the topic that I started to bring it back on topic.
yes there is.. kindly search the phrase "seafoam verdict" and scroll down some
Old 02-21-2006, 03:52 AM
bamachem's Avatar
yeah, but didn't he say something about the BHG also contributing to the cleaner pistons. also, like mentioned, he didn't show pics of the valves, so therefore it isn't relevant to the topic posted here, so the originator won't give a damn anyway...
Old 02-21-2006, 06:26 AM
hross14's Avatar
Simple and cost effective solution to the problem is to get a indoscopic (spelling) camera and send it down into the deep. Right?? I think i recall seeing a advert for one around 150-200 bones. But anyways--they usually have little lights and are very flexible----blah blah. So take a before and after picture and BAM!!. I will research to see whether i can actually find one that can bend enough to make it through. This should give us a picture of the back of the valve(s). WHAT SAYS UDS??
Old 02-21-2006, 06:40 AM
  #25
msw0085's Avatar
yeah i guess reading thoroughly helps.. take it easy, eh?
Old 02-21-2006, 07:17 AM
  #26
bamachem's Avatar
Old 02-21-2006, 04:57 PM
  #27
surf4runner's Avatar
if someone sponsors the parts for a 22re rebuild ill supply the tools and time with of before and after.
Old 02-21-2006, 07:14 PM
  #28
MTL_4runner's Avatar
Endoscopic cameras are used in medical surgeries, but the ones they use are rediculously expensive (at least 10x to 100x more than you mentioned). Show me where to get a guideable endoscope for $100-200 and I'll buy one on the spot.
Redeth005
06-28-2018 08:16 PM
justdifferentials
14
06-11-2017 08:36 PM
nvwiggins
13
06-16-2016 03:05 PM
charlie_fong
09-27-2015 10:06 PM
gyroscope7
7
09-27-2015 08:39 PM
Quick Reply: Sea foam visual challenge
