running boards are off, not sure what to do with the hole?
Old 01-07-2008, 09:37 AM
rdang's Avatar
I'm sure some of you are getting sick of people posting pictures of their 4Runners with their running boards off, I personally can't get enough of it.
Here it is with the boards still on:
With it off:
Question is, for those that did remove their running boards, what did you guys do with this hole? I see a lot mud getting stuck in here and rusting everything out.
Old 01-07-2008, 09:44 AM
tiresrus's Avatar
Looks like you could put a dab of silicone in there
Old 01-07-2008, 09:47 AM
rdang's Avatar
It's a pretty big hole, I don't think a glob would even fill it.
Old 01-07-2008, 10:07 AM
dirtoyboy's Avatar
if u arent putting the running boards back on dont worry about it.
If you are putting them back on just put the original bolts back in
Old 01-07-2008, 10:14 AM
rdang's Avatar
I have rock sliders I need to put on, is everyone referring to the same hole?
Old 01-07-2008, 10:23 AM
dirtoyboy's Avatar
aye sorry, i thought u meant the stock bolt holes...
dunno, maybe a piece of plastic cut to fit and siliconed in place
Old 01-07-2008, 11:32 AM
hross14's Avatar
take those Flares off to and put on sliders--no more hole and added wheeling protection
Old 01-07-2008, 12:31 PM
trd_4runnin11's Avatar
behind the flares and cladding is many more holes, so I wouldn't really suggest that option. I honestly don't see that hole causing any problems so I wouldn't even worry about it, but thats just me.
Old 01-07-2008, 12:39 PM
ornery's Avatar
mudflaps?
Old 01-07-2008, 12:40 PM
MadCityRich's Avatar
Could filling it cause water/salt/dirt to build up behind it and cause rusting? I'm just thinking out loud.
MadCityRich
Old 01-07-2008, 12:41 PM
Guest
seanz0rz's Avatar
mine were full of rotting leaves when i took the running boards off, now they are clean, i dont think the would cake up with mud since the drain down.
Old 01-07-2008, 12:50 PM
hross14's Avatar
Nope, just steel and paint--Take that off and there is nothing else there except pinch welds and maybe some holes from the flares.
Old 01-07-2008, 02:22 PM
Well, the fender flares are connected to the cladding, and there are holes in the body panels behind the flares and cladding. So unless he wants to have a bunch of holes going around his fenders and above his rocker panels, then I'd leave the flares on.
I looked into this as well because when I got my limited I didn't really like the limited flares. I figured .."No problem, I'll just take em off." Only to find out that it is not really that easy.
Old 01-07-2008, 02:31 PM
rdang's Avatar
Yeah, I would leave the flares on - I like the way they look, especially what it will look like once I get my new 33x12.5 swamper SSR's on there.
Old 01-07-2008, 02:44 PM
Whitey13's Avatar
You are saying there are no holes from taking off the flares, just steel and paint, and then you say maybe there are just some holes...FROM THE FLARES??
I'm sure the OP has no interest in taking off his flares anyways. It appears that your truck has a slight lift....I am assuming from the 17" wheels. Are you running 265/70/17 tires?
Old 01-07-2008, 02:48 PM
rdang's Avatar
Yeah, they are 265/70/17 BFG Rugged Trail T/A's, hoping to get rid of them when I get my new rims and tires. Lift will hopefully be going on this weekend (Sonoran Steel 1.1).
Old 01-07-2008, 02:51 PM
Whitey13's Avatar
Are you going to stick with a 17" wheel?
Old 01-07-2008, 03:19 PM
rdang's Avatar
Nah, would have been way to expensive for the wheels - I would like to keep my OEM 17's, but they are just not recommended for 12.5 wide tire (or so I've heard).
Old 01-07-2008, 06:45 PM
notanymore's Avatar
well, you could buy like 3 tubes of silicone and fill it
im not quite sure but couldnt you hammer it flat then silicone it then?
Old 01-07-2008, 07:37 PM
Godzilla's Avatar
I had the same thing, and to help the issue I just put on some front mudflaps from a first gen 4runner using the existing screw holes for the flares on the inside of the wheel well
Quick Reply: running boards are off, not sure what to do with the hole?
