Rough idle at low RPM after carbon cleaning... help please...
After 2 treatments of AC Delco Cleen (1liter for each treatment on 2 successive days throught the braker booster hose) I was sure that a lot of carbon got burned out through the exhaust. The second treatment produced very little white smoke compared to the first treatment a day earlier. I'm now noticing that my engine seems to be idling less smoothly after both treatments. At high RPMs it seems fine.
Did any carbon get dislodged and stuck somewhere? I'm guessing either the EGR valve, EGR vacuum modulator or the O2 sensor got plugged/dirty...
Any suggestions?
Troy
Any suggestions?
Troy
Any suggestions?
Troy
Any suggestions?
Troy
The spark plugs are probably full of junk too. I'd say pull and clean/replace all the plugs then pull and clean the o2 sensor(s) with some throttle body cleaner.
Just an opinion.
Just an opinion.
Spark plugs are clean. In fact the ceramic part was almost white. I guess the cleaner did them also. I'll pull the front O2 sensor and check it. Can it be sprayed with electronic cleaner without harm?
Troy
Troy
Troy
Troy
montanatruck
02-26-2017 07:07 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
