ring pinion 4runner - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 03-18-2005, 01:06 PM   #1 (permalink)
ring pinion 4runner
hallo i have 4runner year 1994 . the problem is ring and pinion front axle.
one of the teeth is broken. the orginal ratio is 39:8.
i tried to buy oem part of precision gear and they told me that if i have this ratio original i must buy toyota parts because it will not feet .
toyota parts cost over 500 $.
if someone have experience with this issue i will happy to get advise .
thanks
danlewin is offline
Old 03-18-2005, 01:10 PM   #2 (permalink)
Silver_Truck's Avatar
Is 39:8 the same as a 4.88:1? If so you should be able to get any aftermarket gear you want and put it in
__________________
-Geoff
*1991 Toyota Pickup Ext. Cab SR5 4x4 V6 5 spd K&N intake, port & polished heads with OS valves, port & polished intake manifold and plenum, NWOR headers and crossover, NWOR catback, Denso Iridium plugs, Redline Fluids, 4.88s, Rear LockRight, Aisin hubs, Chevy springs, BJ spacers, 2" RB body lift, 34x10.5 Swamper LTBs, WolphisWorks Sliders and bumpers, 400,000 mi.
Silver_Truck is offline
Old 03-18-2005, 02:21 PM   #3 (permalink)
Flamedx4's Avatar
Can't even think of a typo that could be (3.889, 3.9 etc) 3.9 is in 2wd autos, never knew what supposedly came with 3.889s.
I know of no front ratio that is not commonly available aftermarket, but there are a few pitfalls to certain rears. None of them is 39.8 though. Try this: http://www.off-road.com/toyota/tech/other/4_axles.html and scroll down to the chart.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 03-18-2005, 02:44 PM   #4 (permalink)
Ahh Yes.. I have been through this one.
The reason you are unable to get aftermarket gears for your original 4.88 front axle is because the ring and pinion spacing is completely different in these axles. Assuming your 4Runner is an auto, just as my truck is, 4.88's were common..
When you go with lower gears, say from 4.10's to 4.88's for example, your pinion gets smaller and the ring gear gets a little thicker. With a smaller pinion, at any given time, you have less gear mesh than with a larger one or taller gears. It is for this reason that you can only go so low with your gears before they start to become to weak.
As a result, when toyota designed the 4.88 gears at the factory, they increased the spacing between the ring gear and the pinion gear, thus strengthening the gears and still allowing the 4.88 ratio. If you tried to put standard aftermarket gears in your diff they would not mesh. On the rear you can simply swap out your 3rd member with one that came with 4.10's factory and purchase aftermarket gears. For the front I am not sure. May have to swap out the entire center section. At least you have the peace of mind knowing that your factory 4.88's are stronger than the next guys aftermarket, but not strong enough in your case.
However, I have heard, that another way around this is to purchase one of the gearless lockers. I have not tried this to verify.
This is the reason I still have my factory 4.88's in my truck as well.
Dirtoy4x4 is offline
Old 03-18-2005, 03:12 PM   #5 (permalink)
thank you
i will print your answer and consult my mechanics .
danlewin is offline
Old 03-18-2005, 07:34 PM   #6 (permalink)
SD70MAC's Avatar
Quote:
39:8 is the ratio of teeth on the drive gear to teeth on the driven gear. 39 divided by 8= 4.875 or rounded to 4.88.
__________________
FOR SALE: 89 4Runner - 3.0. BFG All-Terrain T/As
D&RGW - "Mainline Through The Rockies, Not Around Them"
SD70MAC is offline
Old 03-19-2005, 10:40 AM   #7 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
NO. 4.88 FRONT GEARS ARE NORMAL. Any aftermarket gears will fit. The REAR gears are different and you're stuck there.
I have aftermarket front 5.29s in my front.
http://www.pirate4x4.com/forum/showt...highlight=4.88
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Old 03-22-2005, 11:40 AM   #8 (permalink)
Flamedx4's Avatar
Robinhood is right. Factory 4.88s (8" r&p) have a different carrier in the rear. All the fronts are the same. Lotsa threads here and tech articles on the net about this.
__________________
Flamedx4 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Ring and pinion help? b82ta3 General Vehicle Related Topics (Non Year Related) 8 07-02-2007 08:17 PM
Replacing Ring and Pinion scenarioL113 86-95 Trucks & 4Runners 4 06-03-2007 09:47 PM
Ring and Pinion...Is more better? Denk Offroad Tech 5 10-21-2004 04:14 PM
ring and pinion toy4fun 95.5-2004 Tacomas & 96-2002 4Runners 15 10-09-2003 01:34 PM
2009 InternetBrands, Inc.
