relay clicks when I let off the gas
Old 09-17-2004, 09:48 PM
SlimJim248@earthlink's Avatar
I have an 85 runner, 22re and when I rev it or am driving and let off the gas a relay clicks under the dash, sounds like the passenger side. It just starting happening tonight, so I haven't checked exactly where it is coming from, but I didn't know if anyone has had this problem before. Any help would be appreciated, Thanks.
Old 09-18-2004, 06:53 AM
SoCal4Running's Avatar
I had the same relay "click" happen when my 22re lost a piston ring. It would only click when coasting or idle. It is behind the passenger kick panel.
Never did find out what it was because I knew the motor needed major work, and after rebuilding and cleaning everything it has not come back.
I would check all vacum hoses under the hood and also all the electrical plugs to make sure there tight. Have you tried to pull any codes?
Old 09-18-2004, 08:51 PM
I ran the codes, but it blinks only once, saying it is ok, I think I am gonna have to take it apart and find exactly where it is coming from, Just got back from wheelin today, still clicks, but didn't affect the performance. Thanks
Old 09-18-2004, 09:22 PM
cabbage's Avatar
I believe its your AC, mine does the same, only when the AC is on. The compressor doesnt kick in until the engine reaches a certain rpm.
Old 10-12-2004, 07:27 PM
Well after I blew my head gasket last week I decided it was time to rebuild it because it is pretty tired. my #1 piston had about 1/4 of the compression ring just like SoCal4Running said had happened to him. Thanks for the help.
Old 10-12-2004, 07:31 PM
cabbage's Avatar
Exclamation
I hope the clicking we're talking about is different!!! Glad you found your problem..
Old 10-12-2004, 08:05 PM
Our problem sounds different, my click happened with the a/c on or off, I wouldn't sweat it. Thanks for the help
SubiKing
08-21-2021 03:57 AM
mussy01
12-13-2016 08:20 PM
mluz013
08-02-2015 05:00 AM
Sandman
07-14-2015 12:36 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: relay clicks when I let off the gas
