Rear wiper problem - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-01-2002, 04:54 PM   #1 (permalink)
Paul H.'s Avatar
Rear wiper problem
Have a problem with my rear wiper. When I turn it on the wiper comes down so it is verticle. It then will not move. When I pull it off the window it runs fine but then stops when I put it back on the window. It seems like there is too much downforce on the wiper arm. Is there some kind of adjustment I can make on it? Thanks.
__________________
92 4Runner SR5 V6 4X4
Skyjacker Nitro shocks, Pro-Comp steering stabilizer, clear bumper lenses, lund windjammer, OME standard coils, ISR mod, inlet pipe removed, Bushwaker Fender Flares.
2002 Tacoma Prerunner V6 Xtracab. Lund Intercepter bug guard, rear glass sunshield, Bilstein shocks on rear.
2004 Honda CRV EX stock belongs to wife.
Quote:
Originally Posted by habanero View Post
I did a lot of masticating today.....and now I'm going to go do some more.
Paul H. is offline
Old 09-01-2002, 05:04 PM   #2 (permalink)
Mack's Avatar
Send a message via ICQ to Mack Send a message via AIM to Mack Send a message via Yahoo to Mack
Paul
It almost sounds like the wiper has been knocked off its splines and the park position is now further down, If this is the problem just unbolt the wiper arm and realign its down position, by taking the arm off and putting it back on the splines with the wiper where you want it to be when it parks. re tighten the bolts (but not too tight) and it should work.
Hope that helps
__________________
Mack (David)
Mack's Bigger Better 4Runner Page coming very soon!
1989 Toyota 4Runner Canadian Special Edition
Want a link to your web pages on Mack's friends page?
Two wrongs don't make a right but three rights makes a left
Mack is offline
Old 09-02-2002, 12:37 PM   #3 (permalink)
Paul H.'s Avatar
Mack, it looks like you are right; however I could not figure out how to take the wiper arm off the spline. I could not find the bolts that you are talking about. How do you remove the arm from the spline? Thanks again.
__________________
Paul H. is offline
Old 09-03-2002, 02:32 AM   #4 (permalink)
Fred Anarat's Avatar
Sorry Mack, gonna step on your toes here
I'm assuming that your '92 is like my '90, with the wiper at the top of the rear window.
Look at where the arm attaches to the to the body (motor pivot point in the top mid. of the window). There is a pressed sheet metal cover that will swing up at the point where the pivot for the wiper arm is, you may need a flat screwdriver to work it loose and up. Under that cover is a 10mm nut (whatever that ='s in SAE). Take the nut off, remove the arm and clean/check the splines of the two mating surfaces.
If everything looks good and making sure the motor is in the parked position, re-attach the arm in the parking holder and be careful not to over tighten the nut, or you may crack the aluminum end of the wiper arm.
Is that confusing enough??
__________________
Fred
'90, 2 Door, 22RE, SR5, Coil overs & suspension mods
Rear deflector, Signal & Brakelight mods
Alpine headunit and 8cd changer
Midnight Blue Pearl Metalic paint
More to come, when money allows
"Horsepower through technology, and Cubic Inches
Fred Anarat is offline
Old 09-06-2002, 06:18 PM   #5 (permalink)
Paul H.'s Avatar
Thanks fred, the nut was actually very loose. The splines looked almost completely wore off but I put the wiper arm back on and now it works fine and thanks to you to Mack for your initial call.
__________________
Paul H. is offline
Old 09-06-2002, 08:34 PM   #6 (permalink)
Mack's Avatar
I misread your initial post and thought you were talking about front wipers.
Glad to hear yoiu managed to sort out the problem.
__________________
Mack (David)
Mack is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
windshield wiper problem HELP! aviator 86-95 Trucks & 4Runners 0 03-12-2007 07:17 AM
rear wiper/washer problem Brenjen 86-95 Trucks & 4Runners 8 03-11-2007 08:59 AM
Reoccurring intermittent wiper problem aowRS 95.5-2004 Tacomas & 96-2002 4Runners 9 01-30-2006 05:41 AM
Windshield Wiper problem. bryanr Maintenance & Repair Archives 2 04-12-2005 10:28 AM
Rear wiper problem CBDenver 95.5-2004 Tacomas & 96-2002 4Runners 4 12-19-2003 06:47 PM
2009 InternetBrands, Inc.
