Rear Drum Brake Shoes
Old 08-13-2004, 02:04 PM
vtruong1's Avatar
What kind to get? Does it matter???
Thanks
Old 08-13-2004, 04:25 PM
MTL_4runner's Avatar
Thanks
I am going with OEMs, I have tried others and they are just not as good.
Old 08-13-2004, 04:52 PM
Guest
Yoter's Avatar
I think mine are Bendix, They seem to work fine.
Old 08-13-2004, 04:59 PM
Scofco's Avatar
Bendix is a key manufacturer of semi-truck air brake components.
They know their stuff!
Old 08-13-2004, 06:16 PM
Guest
Yoter's Avatar
Yeah I have semi truck parts on my 4runner. Ok I understand why I remembered that name, I use to drive a rig and somehow that name came up. Might have been printed on the airbrake handle or something. Oh well.
Old 11-06-2004, 08:04 AM
4Runner4Christ's Avatar
Where did you get your Bendix rear shoes? Any other recommendations for rear shoes other than Toyota OEM & Bendix? If so, where did you get them from? Any part numbers for the rear shoes would be appreciated. Thanks
Old 11-06-2004, 10:24 AM
DUOGLIDESS's Avatar
i purchased brake shoes from car quest whos brakes come from bendix but are relabled to the car quest name
Old 11-06-2004, 01:55 PM
vtruong1's Avatar
advanced auto has them
Old 11-06-2004, 02:27 PM
runnerboy97's Avatar
i just redid my rear brakes with carquest parts. the blue shoes the bendix ones. they also carry a hardware kit, which is all new springs, retainers(for the holddown springs and the little horseshoe clips) and the pins that hold the shoes in place, definatly worth the few extra bucks.
Old 11-06-2004, 04:00 PM
VA_Yotaman's Avatar
This brings up a good question...do I have the original rear brakes on my 91? I don't think I've ever done em. I pull the drums on a regular basis, and I've adjusted them occassionally, but they still have plenty left on em. Everything seems to be in order, no leaky wheel cylinders or anything.
Old 11-06-2004, 05:11 PM
k-bomb's Avatar
If it aint broke, don't fix it. I work at a brake shop and I've seen rear brakes last well over 100k miles on the 4runner. If you do replace the shoes, I would recommend replacing the wheel cyliners while your already in there. They're inexpensive and will prevent you from having leaks in the future which will destroy your new brake shoes.
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
rondogracing
07-14-2015 07:00 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Rear Drum Brake Shoes
