Rear diff problem/question.QUICK HELP NEEDED!
Old Nov 12, 2004 | 06:27 PM
84runner's Avatar
Ok guys. Some of you may have read my previous posts about a bad transfer case.
Turns out that it is my REAR DIFF that is making the terrible clunking sound and feeling in my truck.
I need to replace it asap. What is a good price to pay for a used one, and are there any other rear diffs that i could upgrade/change to.
Keep in mind that i have a 1985, 4runner 4wd. but wouldn't mind changing the gears up front if need be.
thanks a bunch for any info
Old Nov 12, 2004 | 06:38 PM
Dirty White Boy's Avatar
Guest
Have you tore down the axle or pulled the drain plug yet? Sounds like R&P. It would definately be a good time to regear f&r in addition to repairing the rear axle (bearings, diff, etc.). Hell, good time to lock if you have not yet done so.
Please excuse my ingorance to your situation, as this is my first 'post'.
Good luck.
Old Nov 12, 2004 | 07:14 PM
Nathan Buchanan's Avatar
where are you at? I have a 4.10 third member I could make you a deal on.
Old Nov 12, 2004 | 10:57 PM
84runner's Avatar
located in san diego. I am told that the part i need to replace is not the "gears" but the part that conects to the driveshaft, and then turns the gears.
Would that be what i need?
If so, how much, and whats the story with it.
thanks!
Old Nov 13, 2004 | 12:46 PM
84runner's Avatar
what is needed to get a locker in the rear?
Do they come stock on other model toyotas? Can i run a locker in the rear, but not the front? What price will i be looking at?
thanks!
Team420
Jan 12, 2021 04:57 PM
merc1100sc
Jun 26, 2015 05:24 PM
cchinny
Jun 25, 2015 08:11 PM
HALMAN
Jun 14, 2002 09:02 PM
