rear axle bearing question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-07-2008, 02:52 PM   #1 (permalink)
I have been having a time with my 4runner rear axle. I think i have it all now but I have a question about the way the rear axle bearing goes in. The one I was sent has a shoulder made on it, I called trdparts4u.com and they said the shoulder went towards the outside of the vehicle however when we pressed it in that way the bearing doesn't sit all the way down in the cage, it is out just a little bit and it doesn't turn as freely as I think it should. Can any one confirm that this is correct? The original didn't have the extra shoulder on it, it was smooth on both sides. I replaced the Axle shaft, the bearing, the seal and the cage that it presses in to. Thanks in advance.
__________________
1998 4-Runner Limited Stock
keithsmith13 is offline
Old 11-08-2008, 03:38 AM   #2 (permalink)
KZN185W's Avatar
i don't recall the wheel bearings to having a shoulder. from what i recall, the bearings were symmetrical and could be installed either way.
part number is 90363-40020 for 1996-2000 models.. late 2000 to 2002 models have the 90363-40068 wheel bearings
__________________
1996 Pearl White Hilux Surf KZN185W SSR-G l 3.0L TDI l Dual Battery l LT285/75R16 l Recaro Seats
Drive Your Dreams
KZN185W is offline
Old 11-08-2008, 07:28 AM   #3 (permalink)
111db's Avatar
Send a message via MSN to 111db
Quote:
I recall the same (above).
You never answered in the other thread: do you have ABS? The reason I ask is that you need to make sure the inner most retainer ring is EXACTLY in the right spot, otherwise you will get axle oil running past the seal. There is only 2mm of leeway for that ring. I found out the hard way.
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 11-08-2008, 03:37 PM   #4 (permalink)
Ok sorry about the delay. Yes I do have antilock brakes and I do have 16" wheels, I ordered the axle accordingly. I took the assembly's to a dealer today that I was close to going to my part time job I explained my trouble they pressed the assembly apart that I felt was wrong and turned the bearing over so the shoulder was towards the inside of the assembly and put it all back together. It turns freely now. I hope tomorrow to get my ride back together. It has been down for two weeks now trying to get this straightened out. I hope this will help someone in the future. To summarize: if you replace the axle, and the inner seal journal is larger than the original, you also have to replace the bearing, cage, and outer seal to new part numbers. the bearing will have a shoulder on it and it goes to the inside of the vehicle.
__________________
Old 11-17-2008, 03:18 AM   #5 (permalink)
KZN185W's Avatar
Thanks for the update.
Can you post pics and part numbers involved?
__________________
Drive Your Dreams
KZN185W is offline
Tags
4runner, 96, axle, bearing, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Rear Axle / Wheel Bearing Removal Question foggysps 95.5-2004 Tacomas & 96-2002 4Runners 1 05-23-2008 09:06 AM
Need bearing retainer for 85 rear axle. gonenomad The Classifieds GraveYard 3 03-24-2008 09:42 AM
Rear Axle Bearing Install Check EvergreenFJ60 95.5-2004 Tacomas & 96-2002 4Runners 11 12-06-2006 08:06 PM
Rear axle bearing.. To replace or not? r854rnr General Vehicle Related Topics (Non Year Related) 12 03-13-2006 06:14 PM
2009 InternetBrands, Inc.
