Q for Engine Gurus
Old Dec 8, 2004 | 11:36 PM
NorCalVP's Avatar
Q for Engine Gurus
This problem is on my 84 Tercel Wagon, not my 4Runner, but I figured i'd ask here to see if anyone has any ideas.
My problem is when i am driving between 65-70MPH, I hear a sound that sounds like pinging, but it isn't pinging. This noise only happens under very specific circumstances. I must be doing between 65-70MPH, on a flat level road, I cannot coast, or put the engine under load. I have to give the engine just enough gas to maintain speed. Once i do this i hear a ratteling from the engine compartment. As soon as i give it a little more or less gas the noise goes away. it's starting to drive me nuts, and i can't just turn up the radio. I drive this car 100 miles per day and don't want to get stranded.
The noise sounds just like the HGLR Ping from a supercharged truck.
Steve
Old Dec 9, 2004 | 05:53 AM
SloPoke's Avatar
Streatched timing chain, worn timing chain guides??? Your probably hearing the chain slap the housing.
Old Dec 9, 2004 | 10:07 AM
NorCalVP's Avatar
I thought of that, but this has a timing belt... (I changed it about a year ago) Just a little more background info.
it's a 1.5L carbed 3A-C engine with a 5 speed tranny. it's got 140K on the clock (original miles)
Steve
Old Dec 9, 2004 | 05:19 PM
arkieoscar's Avatar
It probably is pinging. Sometimes the mixture/timing is only right for pre-ignition under certain conditions. I can fool the knock sensor in my 22re motor with a combination of load and rpm that will make it ping at 2500 rpm. It stops with more throttle. You may want to try a seafoam treatment to clean our some carbon and see if that changes anything.
Old Dec 9, 2004 | 05:31 PM
NorCalVP's Avatar
I'll give that a try to see if it helps, I'll post back with the results.
Steve
Old Dec 9, 2004 | 08:26 PM
alltrac165's Avatar
Another possibility is slight rod knock. That usually shows up under light load conditions, not accelleration or decelleration. Slightly deeper sound than pinging though...
Old Dec 10, 2004 | 05:51 AM
Willcipher's Avatar
Yet another possibility, the 3A and 4A distributor advance mechanism can freeze; causing the shaft to hang in one position. Remove the distributor cap and test the advance using a hand held vaccuum pump. If the nothing moves, it needs to be rebuilt or replaced. This would cause spark knock under certain conditions.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
