pro comp SS brake lines for taco?
Old 07-03-2006, 10:38 AM
d0ubledown's Avatar
ok tundra brakes are on their way. now sourcing out some SS brake lines. pretty much the kit for fronts & rear. local shop has the pro comp ones for the tacoma in stock. would this kit work with my 98 runner? had a look & compared them...but not sure about the rears...are they the same setup?
researched the procomp setup and still debating on them. some say yay most say nay. not sure what other brands are good? i think procomp would be a decent brand..not sure why so many knock em? i know sonoran has the rears, but no front? i'd like to shop local hence the pro comp tacoma kit. but if that doesnt fit ill find another brand or shop online but thats a last resort.
pro comp line users: opinions? did you use the taco kit? how you likin em? would you recommend them?
those running tundra brakes & SS lines: which ones did you use if not the pro comps?
thanks
Old 07-03-2006, 11:58 AM
BajaRunner's Avatar
The Tacoma lines will work. I have them. I actually have the All-pro ones. You might have to get a banjo fitting from an auto parts store to make them work, but, thats no biggie.
Old 07-03-2006, 12:02 PM
ebelen1's Avatar
All-pro has front and rears and so does Goodrich.
Old 07-03-2006, 01:27 PM
DoubleZero4x4's Avatar
thanks
I used the Goodridge SS lines and like them. Not sure if I felt that much of a difference. I did a writeup in the tech section for my 2000 4Runner. If you want the pics that I took while I was doing the mod, PM me with your email address.
Old 07-03-2006, 11:16 PM
d0ubledown's Avatar
hey man yeah that'd help out alot if you could do that...thanks ive gone over your writeup also... but of course pics always help. i ended up scoring a set of pro comp taco lines locally for $30 so ill see how those work...
lcejalvo@telus.net for the pics thanks again
09-04-2015 09:27 AM
88sasturbotoy
08-11-2015 01:56 AM
ripp96
07-25-2015 02:32 PM
87turboPA
07-12-2015 07:49 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: pro comp SS brake lines for taco?
