| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Prerunner and ARB Air Locker
#2 (permalink) |
i believe you have the 8.4" rear end which is the same as the tundra, tacoma (4x4 non e-locker equiped) and sequoia, and the 4th gen 4runners
__________________
97 limited. upgraded on a college budget... Slowly. e-locker traded for a 79 pick up. woooo |
#3 (permalink) |
first off, good choice with the ARB. its a great unit
what you are looking for is the air locker designed for the tacoma 8.4" differential. i dont remember the part # for that, its not the RD23 because thats the 8" one. call an off road shop or drivetrain shop around you and ask some questions. tell them you have the 8.4" or 8.25" rear diff. -Casey |
#4 (permalink) |
Can't answer your application question but I am very happy with my ARB locker. I do mostly street driving in my 4Runner and it's great.
__________________
Steve 1995 4Runner - V6 - 5 Speed Rear ARB, Manual Hubs, Front TruTrac, Marlin Transmission, ARB Front & Sonoran Steel Rear bumpers that have saved my life!! |
#5 (permalink) |
What is a median price for the ARB Air Locker for a Tacoma? Cause i'm seeing numbers way different from each other all around. From $650 to $808 to $940, and the $940 one said compressor sold separetly. Did you guys buy yours local or offline? If offline where from? This is my first truck, so I'm not sure where to buy parts from and all that yet. Also where did you guys mount the switch in your cab? Cause my prerunner has the little slot (has a little plastic filler piece in it) where the RR Diff Lock button would be if the truck had the e locker in it, and I was wondering if the switch would fit there?
__________________
-Noah- 2001 Tacoma Prerunner SR5 4 Cylinder 2.7L |
#6 (permalink) |
I bought mine from All Pro Offroad. I pulled the diff out of my axle and brought it to them. They installed the diff parts - I installed the rest on my truck. I have a 2nd Gen 4 runner and mounted the switches (there are two - compressor and locker) on the center console behind the shifter where a couple of those coin holder trays were. Doing it over again I would buy some toyota factory switches and put them in the dash. I say this because too often things bump the switches turning them on. It's not that big a deal because I disconnect power to the compressor when not wheeling. That way I don't accidently bump on the locker on the freeway.
__________________
#7 (permalink) |
i paid $1400 at drivetrain direct for my rear locker + compressor installed. im sure you could get it done cheaper elsewhere, but thats what i paid.
im sure someone will chime in and tell me i got ripped off, but its in the past, i dont really care anymore |
#8 (permalink) |
You want an RD89 for your PreRunner and yes, the ARB switch will fit in the Toyota knockout perfectly.
Turning the locker on accidentally (or on purpose) on the freeway, etc. will not cause any problems or scary conditions.
__________________
- Erik '86 44runner, '97 T100, '97 4runner, '05 WR450 http://home.4x4wire.com/erik |
#9 (permalink) |
Sweet, but I think that since there are two switches (compressor and locker) I might mount them in the knockouts next to the 2 outlets in front of the shifter. They are side by side and rotated 90CW in comparison to the RR DIFF Lock one on the dash, but same size as it. I was a little worried about putting them there being that my cd book or other object might slide forward and knock it, being that its at seat level, but since you said that it doesnt matter if they are accidentally activated, no worries. Thanks.
__________________
#10 (permalink) |
That's what I did. I'll snap a picture of how I mounted mine if you like. I mainly see my switches turned on when I pick the truck up after service or a car wash. As I mentioned I bleed the air tank down and disconnect the compressor power so it doesn't matter if they're switched on. Even though it won't hurt anything I just don't want it getting bumped on during a turn!
__________________
#11 (permalink) |
yeah a pic would be nice, just so I can see what it will look like to ensure that I want it there. i'm about 99% positive, but a little visual confirmation wouldnt hurt, if its not to much trouble.
__________________
#12 (permalink) |
Here's a pic of my switches. Sorry for the late reply. I've been away on business and I'm just getting back to everything!
__________________
#13 (permalink) |
By the way, I had to do a tiny bit of grinding with my Dremel tool to get the ARB switches to fit in the coin holder holes. Be careful you don't grind too much or they won't snap in the holes properly.
__________________
#14 (permalink) |
If you have the ARB compressor and locker, you cannot engage the locker without first engaging the compressor. Even if you are going down the road and your CD's fall on both switches, you will still not have any scary issues, I just mean to illustrate the chances of it happening are small and there is some safety built into the system.
| Tags |
| 116, 1995, 27l, air, arb, ca, county, fit, front, install, locker, orange, prerunner, sequoia, tacoma, toyota, tranny |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| ARB Air Locker | Knuckles | General Vehicle Related Topics (Non Year Related) | 9 | 10-03-2006 02:09 PM |
| Toyota e-locker or ARB air locker?? | ranma21 | Offroad Tech | 34 | 10-04-2004 09:15 AM |
| ARB Air Locker Concern | GRNTACO | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 08-03-2004 01:49 PM |
| ARB air locker or E-locker | george16 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 03-18-2004 07:45 PM |
| ARB Air Locker Install? | Gene | Off Road Trip Planning, Expeditions, Trips, & Events | 19 | 06-03-2002 08:07 PM |
