Power Door Guts???
Old 01-08-2004, 07:27 AM
Flygtenstein's Avatar
Power Door Guts???
In my 95 runner, power locks, windows and the like, I have lost functional power locking in the driver's door.
Behind the door skin, there is a whole mess of wires, control boxes and crap that seem to be way overkill for what needs to get done in my door.
In Moab this summer, a piece of my window track fell to the bottom of the door, rattled, but did not cause any problems. As a result, I pulled it out and forgot about it.
Now it seems that piece buggered some wiring causing the end of power driver's door lock. This would not be a problem except that I have key-less entry which is not sort of worthless since the driver's door does not lock with power.
The switch that I need is $150 new and the control module that I may need is better than $400.
Is there any better way to fix this?
Does anyone have a rig they are parting that I could pillage the stuff from? I have called the yards locally and none of them have Toyotas with power locks, only a few even had Toyotas.
Old 01-08-2004, 07:42 AM
mt_goat's Avatar
You might try taking the switch apart and cleaning the contacts. That worked for my power window switches last summer.
Old 01-09-2004, 03:48 PM
There is a large module that has some wires sheared off from the falling bracket.
Anyone else have even an idea?
06-01-2021 01:51 PM
westonian18
05-01-2020 06:38 AM
theking11863
03-19-2016 09:36 PM
shisha1999
09-20-2015 11:44 AM
94yotaky
07-23-2015 07:50 AM
Quick Reply: Power Door Guts???
