PCV is easy, my eye!
Mine started to stall a bit when I pulled the pcv line, but as soon as I started pouring the seafoam in, the engine was ok. So if you can have someone pull out the line, and you can start pouring it in quickly afterward(but slow on the liquid so you don't hydrolock) this might work.
Joe-
My engine dies the minute the hose comes off - I'll have to pull on the throttle and find that magic spot when I do mine.
Thanks guys!
Thanks guys!
Originally Posted by Tacoma Dude
Okay so I understand let me recap:
so if the throttle is open the removal of the PCV won't stall the engine?
AIIIIEEEEEEEEEEEEEE!!!!!!!
I go to NAPA and buy a new grommet.
I go home and go to work on the PCV.
I use a mini prybar and break off parts of the grommet (which are as hard as PVC now).
And the stupid thing STILL won't come out!
I can push the stupid thing in but I can't pull it out no matter what I try.
I would take it to Toyota by now but I can't get it out of the driveway because the vaccuum leak makes me stall out :pat:
Maybe I should just SHOOT the damned thing out!
#26
Can you get at it from below?
If you can I'm thinking maybe I'll just remove the rocker arm cover and take it out there. The stupid thing will push in...
#28
Stupid PCV...
It's the grommet that's the problem. In the 150K miles this thing has seen I don't think it's ever been replaced.
Every single item on here that's been replaced is an aftermarket part.
This PCV says Toyota on it. Enough for me to believe that this grommet has never been changed out and when I say it's as hard as PVC, I mean it - it's like really hard plastic now
#30
#31
Okay... FINALLY got the stupid thing out.
I got a good enough vaccuum seal to get to a Firestone service shop and asked the guy about the PCV and he was like, "that little thing??? Bring it by over the week and I'll see if I can take care of it. Did you try some WD40?"
Well, I went home ate a late lunch and thought about the WD40. Don't know why I didn't think about using some kind of lubricant.
Spritzed and said "Goddamned stupid freaking PCV" quite a few times and FINALLY popped the stupid thing out!!!
*Sigh*
I feel so content now
*Sigh*
#32
Dumb question here. The pvc is in the plastic 90 degree bend? The replacement I got is a straight piece of metal. I popped out the bend easy enough but would be damned if I could get the metal out of the plastic, if it even should. Thanks!
punks_is_4x4
02-26-2016 04:29 PM
kbpickens
10-02-2015 03:37 PM
