Part #'s for 3rd Gen. SR5 front mudflaps are in this post
Old 08-13-2003, 11:02 AM
4RunnerFever's Avatar
Several people are asking about the mudflaps for SR5 3rd gens so I thought I'd just make a new post about it. Hope this helps.
Here are the part numbers/description:
PT413-35966-DF MUDGUARD, FR LH
PT413-35966-PF MUDGUARD, FR RH
Old 08-13-2003, 11:09 AM
waskillywabbit's Avatar
mgspann
You get yours put on yet? My fender flares are going to need some Forever Black now big time! I'm going to take mine off this week and Forever Black them real good, do jalaber's fender flare gasket mod, and wax the fenders real good and do some touch up paint before I put them back on.
Brian
Old 08-13-2003, 11:12 AM
TIP FOR INSTALLATION
There are five attach points on each mudflap, i hex head bolt that goes into the bottom of the rocker panel, 2 hex head screws that go into where you took off the running boards and two anchor type screws that go into holes in the existing fender flare!
TIP: Get a drill and drill out the holes just a tad in the mudflap that the anchor type screws go into so they push in easily. The screws are plastic and won't be forced in and drilling the tight plastic holes let them slide in with ease!
Hope this helps!
Brian
You beat me to the punch on the other post about the flare edge mod.
Cool
Old 08-13-2003, 11:52 AM
nrgetic99's Avatar
Re: TIP FOR INSTALLATION
Brian [/B]
Brian,
I don't think you need to do that. The correct fasteners have a core down the center which expands it once its in place. Simply remove the core and the fitting can be compressed to a much smaller diameter.
Once its in place, reinsert core (looks like a black plastic screw) and the fittings expand.
David
Old 08-13-2003, 11:54 AM
Core
I did have the core out and it was still a real tight fit so I just drilled them a tad so they would go right in with minimal pressure. Then when I put the core screw in it screwed right in, clicked when the anchor expanded and help them puppies right in place perfect. I think that the holes in the plastic were just tight for some reason.
Brian
Team420
01-12-2021 04:57 PM
Niameyrider
06-25-2015 05:50 AM
dirtrider0129
10
06-24-2015 12:24 PM
westbound
06-07-2002 03:30 PM
Quick Reply: Part #'s for 3rd Gen. SR5 front mudflaps are in this post
