open door switch inop
new guy here from the land of the midnight sun,
ever since the temps started getting into the below zero range, the switch that turns my dome light on when the door opens has seem to malfunction. i don't care about the dome light, but the wiring is set up to switch the headlights off when the door opens and the ignition is off.
driver door is the only one effected, the other 3 turn the dome light on.
anyone else ever seen this. im going to pull the switch and see if i can short the wires and see if its a switch problem or a wiring problem
edit; i guess it would be usefull to state that the vehicle in question is a 2002 4runner 4wd
theking11863
03-19-2016 09:36 PM
britishdudes2dr
07-25-2015 06:47 AM
