OME Shock Question
Old Sep 29, 2006 | 05:22 AM
pinkfloyd73's Avatar
OME Shock Question
Can you run OME shocks with 0" lift or do they raise the truck a little?
Old Sep 29, 2006 | 06:33 AM
callmej75's Avatar
Shocks won't lift you...you can run them with 0" lift but your chances of the shock bottoming out and causing damage to the shock is likely to happen over time. Thats my opinion...but OME shocks are pretty tough. You might find an OME shock that is equivalent to your height. PM strap22 and he will give you the scoop on it since he sells them...
Old Sep 29, 2006 | 06:37 AM
bamachem's Avatar
actually, shocks on the front of a 3rd gen can provide lift. if the lower shock cup is farther up the shock body than the stock location, then it will provide some lift. on a 2nd gen with torsion bars, no lift can be achieved by changing shocks.
if you're talking about using OME shocks on a 3rd gen with no lift, i wouldn't advise it. you can, but they're pricey. go with the Tokico Trek Masters if you don't like the stock ones...
Old Sep 29, 2006 | 06:38 AM
callmej75's Avatar
I guess that would be the first question that should have been asked...what are these going on?
nvdesertrunner
May 11, 2020 08:18 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
4Runnin2000
Jul 29, 2015 06:09 PM
SMOD
Jul 27, 2015 01:45 PM
Massmayhem247
Jul 18, 2015 05:46 AM
