OEM vs. aftermarket rear axle bearings...
My rear axle bearings need replacing on my 3rd gen 4runner. I just got quoted $605+taxes for both axle bearings from the dealership (these are only the bearings, no install, no seals, nothing else). So my question: What is your opinion of OEM ($605+) versus aftermarket ($180) rear axle bearings. I prefer to use OEM but am having a hard time getting over the price.
One of my friends suggested 555 (triple fives) as an option but I haven't priced them out yet. Any other suggestions for a good aftermarket rear axle bearing? I believe you get what you pay for, but $605 seems outrageous for two axle bearings. Is there any brand that is close to OEM without the crazy price?
Looking forward to your replys, Cheers.
Axle Assembly
I was about to post this link about which after market (brand) is good flex for our lifted 4R. I read about A1 Cardone Axle and there report sound good.
http://www.cardone.com/English/Club/...Drivetrain.asp
http://www.autopartswarehouse.com/se...294967265+9274
$605 for 2 bearings, I hope they supply the lube and a comfy place to rest your elbows while you're bent over
This place has them from $46, SKF and Timken are both good brands.
http://www.toyautoparts.com/catalog/...7265+1725+9265
Triple 5 is an OEM supplier for toyota. I would think they would work pretty good. Just remember you get what you pay for.
How many miles are on the old bearings?
Cheers
Cheers
Thanks for your feed back. I ended up getting "NPN Bearings" (I am going by my invoice so NPN might stand for something), they were recommended as a good aftermarket brand by a guy who works at a yota dealership. $70/each bearing. Also got me Brembo rear brake shoes, the rest (seals inner/outer etc.) is Toyota OEM. Should all be completed by me, with help from my mechanic (he has a bearing press), on Friday.
Cheers
Cheers
Flying91
45
04-11-2024 04:39 PM
jerusry
10-19-2015 05:28 PM
