OEM 5 stars & 285's
Old 01-09-2007, 10:56 AM
StretchASU's Avatar
OEM 5 stars & 285's
Just wondering if anyone on here is running a 285/75 Goodyear MTR on the stock 5 stars. If so what rubbing issues if any are you having?
Old 01-09-2007, 10:59 AM
Localmotion's Avatar
its a toss up in the air as to whether or not you will rub on your A-arm. I am assuming you have a lift as well as a body lift.
Old 01-09-2007, 11:29 AM
StretchASU's Avatar
Yeah TRD/LC setup. No body lift yet...thats soon.
Old 01-09-2007, 11:59 AM
calrockx's Avatar
i had that setup for a while.
2.5" suspension lift, 1.5" body lift, camburg a-arms.
full stuff at turn....it rubbed slightly, nothing to worry about tho.
Old 01-09-2007, 03:37 PM
CTRJ's Avatar
I run 285 on the stock wheels and only rub at full lock and if the front suspension is allowed full droop, the tires will rub the upper control arm.
Old 01-09-2007, 05:36 PM
neliconcept's Avatar
wheel spacers will fix that issue if you want to work with some 1/4 or 1/2 inch spacers
dont need to go bigger though
Old 01-10-2007, 03:29 PM
Jonathan's Avatar
I rubbed with stock a-arms when stuffed. I have ATS arms now with no problem whatsoever except occasionally rubbing on the frame rails.
Old 01-10-2007, 06:15 PM
StretchASU's Avatar
Thanks for all the help guys. I have a 1/4" spacer on the way just in case.
Old 01-11-2007, 12:52 PM
StretchASU's Avatar
No Rubbing issues at all yet. YEAHHH
HiLuxer
01-06-2016 11:34 AM
IntoTheVoid
10-24-2015 04:54 PM
JookUpVandetti
09-30-2015 08:58 AM
4runnerFireman
09-29-2015 06:24 AM
AlexJet
09-14-2015 09:00 AM
Quick Reply: OEM 5 stars & 285's
