not going in to gear?
Old 10-11-2005, 02:41 PM
runner126's Avatar
I have 94 runner, its been having some trans. problems. In the first few minutes after starting the car (cold)the trans works ok. After it heats up it seems to mess up. After i stop at a red light and i want to put it back into gear it takes "the strength of ten men" to get it into 1st with a nasty pop sound (feels bad). If i put it into reverse first, it makes a gride noise (that you can feel inside) and then i can put it into first and finally start to move. The shifter works fine when the car is off and put it through some gear changes first. but when the car is on, the clutch seems to not be disengaging all the way?. Something still seems to be moving.? Any help is greatly appreciated.
Old 10-11-2005, 03:20 PM
runner126's Avatar
more
also the trans is rough through every gear, really loose feel as well
Old 10-11-2005, 03:21 PM
Localmotion's Avatar
maybe you need a new clutch?
Old 10-11-2005, 09:26 PM
Waterboy's Avatar
You're not the only one.
https://www.yotatech.com/forums/f2/5sp-wont-go-into-gear-28319/
I've just gotten used to it and hardly notice it when it happens anymore.
Old 10-12-2005, 05:36 AM
Adam F's Avatar
Probably the clutch. Mine did simmilar things and turned out there was a broken spring on the clutch disk.
Old 10-15-2005, 05:13 AM
84sr5yoty's Avatar
Time to replace your shifter seat and bushing. Here is the thread that is involved with this.
https://www.yotatech.com/forums/show...t=seat+bushing
Here is the website that explains the replacement proceedure.
http://www.off-road.com/toyota/tech/shifter/index.html
mskalmus
05-28-2017 07:51 AM
norcal98
08-10-2015 06:20 AM
wolfpackfan33
08-02-2015 03:36 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: not going in to gear?
