Newbie Spare Tire Question, please help!
Old 05-21-2003, 09:23 AM
mchan77's Avatar
Hey Everyone,
I went ahead and purchased the downey rear springs, bilstein hd shocks and OME stearing stab. I have finished the front and it changed the attitude of the 93 4Runner like 200%. Before the truck would shimmy like crazy even at around 30mph. Now, it pretty much holds a straight line.
My question is... since I never owned a truck before, how do you release the spare tire from under the truck? I want to do the rear shocks and springs tonight, so any help would be greatly appreciated.
Thanks in advance!
M
Old 05-21-2003, 09:44 AM
02Runner's Avatar
There is an extension rod and handle in the jack bag. One end with a hook. This hook goes just above the bumper into the crank above the spare tire. Crank it down. It is held up by a cable. You see, look above your bumper in the center and you'll see what I'm talking about. Sorry no, pics!
I had the same experience!
Old 05-21-2003, 09:45 AM
Tacoma Dude's Avatar
Welcome to the board Mchan!
Old 05-21-2003, 09:46 AM
Co-Founder/Administrator
Staff
kctopher's Avatar
Release???
Under your backseats should be a metal rod, this goes into the center hole on your bumper, all you do is crank it counter clockwise until you have enough slack released to remove your spare.
This should be all that is needed to remove your spare for the 2nd gens though its been a while since Ive seen one..
Chris
Old 05-21-2003, 09:47 AM
Stump1883's Avatar
I'm guessing that the jack is in the same place on your 93' as my 96'. Get ou your jack from under the passenger side rear seat and take the bar that you use to trn and lift the jack,take it and stick it in the little slot/hole above the rear bumper. Wait till it catches and then start cranking, you will see the spare tire start to drop from the rear. Hope that helps, and it's not to late. Good luck, and take pictures.
Old 05-21-2003, 09:54 AM
mchan77's Avatar
Spare Tire
Hey Guys,
Thanks for all the input, I do appreciate it. I will try to get the rear shocks and springs in tonight and will take some picture. Any hints/advise on the rear shocks? It looks like a pain to get to the top nut. I have a spring compressor, so the springs do not look like a big deal.
Thanks again
Mike
Old 05-21-2003, 10:46 AM
Bob_98SR5's Avatar
MChan,
Read my write up here: http://www.4runners.org/articles/typerdiff/
You'll see pics of exactly what you need to do to get your spare off.
While you're down there, might as well extend your rear differential breather. If you need a Type R diff, email me or Mertztr (Tom) for it. Tom is the Bay Area rep for this part. The HP gains will amaze you---ask around!
Bob
Old 05-21-2003, 11:19 AM
Woodbert's Avatar
Originally posted by Bob_98SR5
MChan,
Bob
Bob,
Old 05-21-2003, 11:21 AM
Bob_98SR5's Avatar
(Woody, stop ruining my fun. Jeesh!)
Old 05-21-2003, 02:35 PM
mchan77's Avatar
Breather
So... I take it that this mod would not be required if I do not go off road? I may do it eventually, where can I purchase the parts? Thanks
Mike
Old 05-21-2003, 04:41 PM
Woodbert's Avatar
MChan,
Bob
MChan,
I was just being a smart a$$. The rear diff HP gains is pretty impressive.
Old 05-21-2003, 06:37 PM
Cebby's Avatar
Originally posted by Woodbert
MChan,
Now I don't even know if you're full of it...you guys are brutal. MChan - No HP from the breather - although a TRD sticker is another matter entirely...
Old 05-21-2003, 08:44 PM
Woodbert's Avatar
I did get better gas mileage when I put the TRD valve stem caps on my tires. Tire wear is much more even now as well.
Anyone got any 120 grit sandpaper for the scratches I need to get rid of?
Old 05-21-2003, 09:11 PM
Bob_98SR5's Avatar
Mike,
In all seriousness, you should do the rear diff breather mod. Who knows when or where you might have to cross a deep puddle from a broken water main or a creek bed. You'll just be glad that you did it.
The time spent will be about 2 hours, even for a newbie.
The parts: any Toyota dealership or an online parts store. I patronize partznet.com b/c they've been good to me since my first order. The parts alone won't break the bank.
Bob
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
DrZero
18
07-24-2015 11:31 PM
DrZero
07-13-2015 09:59 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Newbie Spare Tire Question, please help!
