Newbe here! I have Questions - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-30-2004, 11:25 PM   #1 (permalink)
First of all I would like to say hello to all of you fellow yotatech people. It seems like a great place to get help on all sorts of topics so thats why I'm here! Second I think I have a slight problem... my truck is the one listed in my sig and seems to have a very low and rough idle sometimes. I increased the idle a little bit to see if that would help and it didn't really cure the problem. When I first got the truck 1 year ago I talked to the service guy at my local toyota dealer and he said my throttle body might need to be cleaned. If any of you guys had this problem could you please tell me how to cure it is driving me crazy! Thanks
__________________
1993 Toyota Truck... Blue 22re w/145,000 5 speed
31x10.50 BFG Mud Terrains
Bilstein Shocks
15x8 Black Rockcrawlers
K&N Airfilter with drilled out airbox.
Black TJM T17 with PIAA 520's mounted on top!
more soon!!
93bluetoyota is offline
Old 06-30-2004, 11:30 PM   #2 (permalink)
bike4miles's Avatar
Send a message via Yahoo to bike4miles
One thing I noticed is that my truck idles really slow when it is hot and as a result i have to back out the adjustment screw in the summer to boost my idle up to 700 or 800 rpm.
__________________
--Miles
Sold
'91 4runner, 22re, 5 spd manual, 180,000 miles,
cone filter, Downey 1.5"HD coils, SkyJacker Nitrogens, Magnaflow Exhaust, Stull grill, Clears all around. Check out my sound proofing project and other mods:
My 4runner page
My 2006 Camry page
I'm a Myspace Addict!
bike4miles is offline
Old 06-30-2004, 11:36 PM   #3 (permalink)
Quote:
does it shake and act like its gonna die almost? Mine will get down to about 500rpm. Its very annoying!
__________________
Bilstein Shocks
more soon!!
Old 06-30-2004, 11:51 PM   #4 (permalink)
ChickenLover's Avatar
Instead of trying to pin point the problem, If I were you I would do an all out tune up and just take care of all the possiblities.
-Spark plugs
-Spark plug wires
-Cap and rotor
-Fuel filter
-Clean your K&N
-Change your oil (synthetic)
-Take off your Throttle body and clean it
While your throttle body is off you can take off your plenum and clean it and while it's off replace the pcv valve and clean out the intake manifold. (this is considerably more difficult than the things listed above).
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k)
ChickenLover is offline
Old 06-30-2004, 11:52 PM   #5 (permalink)
bike4miles's Avatar
It did before I replaced my throtle body! The door was worn and it was letting air leak past! If everything is if good working order it should idle smooth at 500 rpm. Definetly clean and check the trotlle body to make sure is is closing compleetly and sealing well. I waised abour $500 trying to figure out a idle problem before I found out I just needed to get a $60 junkyard throtle body!
__________________
--Miles
Sold
My 4runner page
My 2006 Camry page
Old 06-30-2004, 11:55 PM   #6 (permalink)
bike4miles's Avatar
Quote:
-Spark plugs
-Spark plug wires
-Cap and rotor
-Fuel filter
-Clean your K&N
Yea, good idea. I would also recomend an Oxigen sensor if it's never been replaced. This changed the way my truck ran and I got about 2 MPG better gas milage.
__________________
--Miles
Sold
My 4runner page
My 2006 Camry page
Old 07-01-2004, 12:00 AM   #7 (permalink)
-Spark plugs
-Spark plug wires
-Cap and rotor
-Fuel filter
-Clean your K&N
Hey thanks for the ideas is it hard to take off the throttle body and clean it? What do i use to clean it? Thanks
__________________
Bilstein Shocks
more soon!!
Old 07-01-2004, 12:11 AM   #8 (permalink)
bike4miles's Avatar
To clean the throtle body, just take that big hose off that runs over your radiator. All you need is a screw driver. Then you have access to the door which you can clean with a rag. I forget what type of cleaner you are alloud to use but as an auto part store. They will know. It sould take you less than half an hour.
__________________
--Miles
Sold
My 4runner page
My 2006 Camry page
Old 07-01-2004, 08:27 AM   #9 (permalink)
Flamedx4's Avatar
You might also run some injector cleaner through it.
__________________
All my Yotas are gone. Stuff to sell: http://www.yotatech.com/showthread.p...39#post1009839 -Phil
Flamedx4 is offline
Old 07-01-2004, 08:40 AM   #10 (permalink)
88yotaboy's Avatar
My truck had the same problems. Adjusting the timing fixed it.
__________________
2001 Tacoma 3.4 V6 5spd SR5 TRD 4x4
86 4runner sas, 35s
88yotaboy is offline
Old 07-01-2004, 09:44 AM   #11 (permalink)
PirateFins's Avatar
Send a message via AIM to PirateFins Send a message via Yahoo to PirateFins
I agree with everyone else. Do all of the tune up and cleaning, use SENSOR SAFE cleaner . Check the timming. Change the 02 sensor. Check and adjust the TPS. Get yourself a good repair manual, if you don't have one. If you don't understand something just ask, we all are here to help each other. My truck was doing something like what you are describing and it turned out to be bad plugs and wires. When you replace the plugs only use the NGK or Denso plugs they work the best.
Oh by the way Welcome to YT!!
__________________
Brad
Work is for those who don't know how to plunder!!
Quote:
Originally Posted by habanero View Post
I'd experience an O so big it'd show up on the richter scale.
92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money!
04 F150 FX4 SuperCrew
PirateFins is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Colorado 4runner owner (newbe) vwfastg60 Colorado 6 10-19-2006 03:37 AM
Newbe says hi linuxrunner Off Topic Talk 19 12-02-2005 08:35 AM
86 sr5turbo(newbe) vwfastg60 4Runners-1st gen 4 06-04-2005 05:35 AM
Proper Introduction from a Newbe Woodbert 95.5-2004 Tacomas & 96-2002 4Runners 12 01-29-2003 07:58 PM
Oil Change newbe springer91 95.5-2004 Tacomas & 96-2002 4Runners 3 08-13-2002 02:30 PM
2009 InternetBrands, Inc.
