new t-belt/water pump= knocking
Old 04-20-2007, 04:59 PM
kenai's Avatar
Okay so i did my new timing belt and water pump today and now i have a nasty knock coming from the engine. knock increases with engine speed. Anyone else ever experienced this. The engine runs great and everything seems normal but the sound! I will dive back into it, but was curious if anyone had this happen before.
Old 04-20-2007, 05:05 PM
My814x4's Avatar
Check the upper idler bearing , it is the one that the upper rad. hose hooks to
Old 04-20-2007, 05:20 PM
kenai's Avatar
I did replace the lower idler as it was kinda noisy...the upper appeared to be in good shape and noise free so i left it be.
Old 04-21-2007, 06:48 AM
My814x4's Avatar
With it running put your hand on the upper hose housing and you can feel it knocking. Or take a stethescope and listen to it .
Old 04-21-2007, 08:49 AM
kenai's Avatar
Well its not the idler because i pulled the front cover off and used a stethescope. Its is actually coming from the aluminum front cover that has the fan bearing on it. Is its possible that i have my accessory belts too tight? I remember inspecting this part and it seemed tight as a whistle w/ no noise before. BTW the noise is less than it was yesterday.
Old 04-22-2007, 05:23 AM
My814x4's Avatar
Yes it is possible that you over tightened a belt , loosen them up one by one and listen if the noise lessens or goes away.
raptor510
08-19-2015 02:15 PM
Tacoma1313
08-17-2015 05:44 PM
TJWilly
07-31-2015 02:05 PM
Jonny246
07-24-2015 12:37 PM
keithporter83
07-18-2015 12:37 PM
Quick Reply: new t-belt/water pump= knocking
