New Steering Rack Bushings = No shaky!!!
Old 09-18-2008, 04:10 AM
Quattro15's Avatar
I installed some new steering rack bushings that I just bought from WabFab Offroad. My rig no longer shakes at 65-70 mph!!
Everything feels a little tighter as well!
Quite an awesome mod for 30 bucks!!
Old 09-18-2008, 04:26 AM
mkgarrison5's Avatar
Originally Posted by Quattro15
I installed some new steering rack bushings that I just bought from WabFab Offroad. My rig no longer shakes at 65-70 miles per hour!!
did you put them on yourself quatro? btw how are ya? how many miles on that truck of yours?
Old 09-18-2008, 04:33 AM
Quattro15's Avatar
160k....i put them on myself. Took a hour or so but most of that time was spent breaking the old bolts loose.
I'm doin well too Mk.....how about yourself?
Old 09-18-2008, 05:58 AM
trbizwiz's Avatar
what parts exactly are involved in the steering rack? Do you care to give a synopsis of your installation?
Old 09-18-2008, 06:01 AM
waskillywabbit's Avatar
Swapping out the steering bushings is loads of good clean fun.
Glad it worked out well and thanks for the business.
Old 09-18-2008, 11:23 AM
doing good just busy man thanks for asking.... did you take pics and or type up a rundown of how you did it?? usually thats a cool thing to post on this site for others to follow ................ like myself cough cough
Old 09-18-2008, 12:54 PM
cackalak han's Avatar
Ehmm, me, too. Any special tools needed for this? I've been putting this off for way too long. Need to get it done before the snow starts falling. Will be doing the sway bar bushings along with this.
Old 09-18-2008, 03:08 PM
Quattro15's Avatar
There's really not that much to it.
Step 1 : Order the kit from WabFab
Bushings Kit
The kit is at the bottom of the page.
Step 2 : Look at this walkthrough if you want....I didn't need it as it's pretty straight forward. There are also instructions in the kit from Wabfab.
Bushing Install
Step 3 : Do it MAN!!!
Some of those bolts are on there son! So be sure you have a breaker bar if you got your truck on a lift or something so you can use something that large. I used a baby sledge to beat my bolts loose since I have no lift to put the truck on.
Some things to consider are that it's MUCH easier to move the rack around when your tires are off the ground. You'll need to be able to do this to line everything up and also to take the old bushings out.
You kinda have to beat the hell out of the old ones to get them out though, so don't be scared! The new ones go in MUCH easier though!
Also...there are TWO metal sleeves for one of the bushings. I think that this is a cure all solution because you'll only need one. Whichever one your bolt goes through for that part of the rack is the one you'll need to use. I needed the larger diameter sleeve.
The walkthrough that I've provided a link to is incorrect that you'll need to bore out anything. I think this is what the larger sleeve is the fix for. Maybe TRD vs Non-TRD or 2wd vs 4wd bushings?? I don't know? One will work though!
All in all it took me about an hour to do. Most of that time was getting the bolts loose.
Oh....I almost forgot. The large bolt in the rack requires a 22mm socket on both ends. I didn't have one and used an adjustable wrench. Just be sure you have something that can get around that sucker!
I hope this helps guys.
Old 09-18-2008, 03:13 PM
Quattro15's Avatar
No problem! I appreciate you having the bushings! The stealership won't sell them...you have to buy the whole rack!!!!
Old 09-18-2008, 05:50 PM
Quattro15's Avatar
Where did you get those bushings? Also...do you have an install walkthrough for them?
Old 09-18-2008, 06:33 PM
Quattro - I ordered them through Wheeler's. They are Energy Suspension. They gave me 2 sets, because I guess Tacoma's/4Runners have two different sized sway bars. They told me to send them back which ever I don't use for credit.
The walk through is not even necessary. If you can do the steering rack bushings, this will be a walk in the park. I did this in my last 4Runner and it took 20 minutes, which was mostly used up by undoing the bolts. Basically, unbolt the two brackets, off with the old bushings, in with the new and bolt up. Easy as pie.
Old 01-03-2009, 02:56 PM
Ron Helmuth's Avatar
guys sorry to be such a noob but how does one examine the bushings for failure-is there anything to see ?
cack you did this? did it improve sterring feel and other things on your 'Coma?
Old 01-03-2009, 05:44 PM
2000t4rAKS's Avatar
I need to do mine for sure because my center one is tearing. I can see a rubber tear coming out of the sleeve.
Will be ordering one from Wheeler's very soon.
You can examine it by taking off the skid plate and towards the front of the rig from the transfer case.
Old 01-04-2009, 08:12 AM
thank you 2000t4raks
okay so it is physical damage that indicates a problem I gather....
thanks for the feedback.
1uzRunner
63
11-10-2018 03:58 PM
Papadeath
09-14-2015 10:26 PM
Pocoyota
09-08-2015 02:41 PM
128keaton
09-03-2015 05:09 PM
dguzzi
09-03-2015 08:48 AM
Quick Reply: New Steering Rack Bushings = No shaky!!!
