Need help with rear end please.
Old 03-11-2003, 03:58 PM
toyo's Avatar
About 1 out of 10 times when I put my truck in gear, take off it makes a jolt type noise in the rear. But this where I am really getting concerned. Today i noticed that something in the rear is diff not right. If I am coasting to a light, put clutch in and take off something is holding me back. Its like something is sticking or not releasing. I just bought this thing yesterday. It's a 87 with 84k miles on it. I changed all fluids today, diff fluid wasnt too bad. Anybody have any thoughts. I was thinking maybe the rear axle bearings are bad or may be something in the rear brakes are not releasing. I will pull the drums off this weekend.
Old 03-11-2003, 04:05 PM
HBoss's Avatar
Sounds like the drums. I had a very similar problem until I got the rear brakes adjusted. It would sometimes back out or go forward with a clunk to start. Went away after the brake adjustment.
Old 03-11-2003, 04:09 PM
toyo's Avatar
Thanks for the advice, I will pull them off to see. The noise I am hearing is a little high pitched I think for the drums. I hope its not the gears in the chunk going bad. Now that I think about it, the e brake is very tight, so maybe the holding back problem is the shoes. I hope so.
tj884Rdlx
08-28-2015 12:04 PM
Daneums
08-20-2015 05:36 AM
rondogracing
07-14-2015 07:00 PM
hangtown88toy
07-10-2015 02:33 PM
akaphilly
07-09-2015 02:18 PM
Quick Reply: Need help with rear end please.
