need help
Old 03-29-2004, 01:47 PM
86_4runner's Avatar
need help
hi
is it possible to use a 22r engine from a 84 pickup in a 89 pickup that is a 22re?
Old 03-29-2004, 02:26 PM
86_4runner's Avatar
can you swap the two engines? use the 84 engine in the 89.
Old 03-29-2004, 02:28 PM
Guest
oly884's Avatar
Nope. The engine that you put in your 89 has to be the same year or newer. Plus the 22r is carburated where as the 22re is EFI.
Old 03-29-2004, 02:35 PM
tallboy's Avatar
Originally Posted by 86_4runner
hi
A 22r and 22re are very simulliar but not the same. You get a little more horse power out of 22re. The intrenal workings are diffrent as well as some external and these things are not interchangeable.
Old 03-31-2004, 03:00 PM
86_4runner's Avatar
well I did a little research and i found that you can swap the two motors. I talked to someone who done it on there 4runner.
Old 03-31-2004, 03:17 PM
anthony1's Avatar
The law vary from state to state. Check with DMV to see if you can swap an engine from older vehicle to newer vehicle.
other than that, go for it.
Old 03-31-2004, 06:45 PM
tallboy's Avatar
Just make sure you use the balancer and fly wheel for the motor you use. A friend of mine bought a reman motor for his 84 and the motor had the wrong oil pump on it. 85 they changed the oil pump, 85 and later the oil pump sticks out I think it is about a 1/4 to 1/8" further. It sucked when he put the balancer on and motor locked up I don't Know if you are carb. or injected, but also keep in mind if you are injected and the other motor is carb. there may not be a provison for a knock sensor. That is what I'am talking about just the little stuff that would drive a man to drink lots of beer.
Good luck!!!!!!!!
