mud flaps
Old 12-13-2005, 02:16 PM
dirtypuke's Avatar
mud flaps
hi i was wondering if you guys know if these mud flaps will fit with the sr5 black plastic fender flares? or does toyota make some? i cant wait to take my running boards off.http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old 12-13-2005, 02:37 PM
2000t4r's Avatar
I don't think that they do you need to order part number 00547-35966df,
00547-35961pf
Old 12-13-2005, 02:44 PM
AznSky's Avatar
Or you could buy my stock mudflaps for 20 bucks plus shipping.
https://www.yotatech.com/forums/show...hlight=mudflap
Old 12-13-2005, 02:49 PM
ebelen1's Avatar
Those will not bolt on the SR5 flares. Also, SR5 flares changed in 01 or 02 to be the same as the limited flares from prior years.
Old 12-14-2005, 05:02 AM
dirtypuke's Avatar
cool thanks guys, and i am probably just going to find some new ones. thanks anyways.
Old 12-14-2005, 05:56 AM
ebelen1's Avatar
1sttoyotaparts has them for about $50 shipped for the pair. The local stealership wanted over $100 plus tax. I was trying to dig up the part numbers but couldn't find them. The part numbers are located somewhere on this board so good luck.
Old 12-23-2005, 01:13 PM
dirtypuke's Avatar
so i called 1sttoyotaparts and they said that these mud flaps will not work with my fender flares? what do you guys with the sr5 fender flares and the running boards from the factory use when you pull the running boards off?
Old 12-23-2005, 01:55 PM
ebelen1's Avatar
First off, this response is only if you have the SR5 flares that are the "street style" ones. If you have the SR5 flares from 01 and 02, the following will not help you. If you have a 3rd gen SR5 from prior to 01, read on.
I took my running boards off and trimmed the part that pertrudes past the body in the rears. Here's a pic:
Here's a pic of the front and rear mud flaps from a side view. Note that my rear mud flaps are stock but I bought the front ones after removing the running boards. I believe the front ones are the ones you're looking for.
Old 12-23-2005, 02:15 PM
Beerdrinker's Avatar
I have a 99 SR5, removed my running boards, frt mud flap part numbers I used were pt413-35966-df and pt413-35966-pf
they are the same as ebelen1's picture
Old 12-24-2005, 05:28 AM
dirtypuke's Avatar
cool thanks guys, i ordered the mud flaps. as soon as i get them my boards are coming off.
Toys4parts
09-26-2015 01:56 PM
tysen86
09-25-2015 11:15 PM
Adam Edgar
09-20-2015 03:24 AM
auscal
09-19-2015 12:15 PM
Jake28296
09-16-2015 06:10 AM
Quick Reply: mud flaps
