Master window switch swap questions
Old 09-16-2014, 12:53 AM
Snowheeler's Avatar
As is so common in our rigs, the passenger window finger switch is bad in the master panel of my 97. So in thinking about replacing it, I wondered if I could swap in a whole new master panel from a slightly newer 3rd gen with the auto up/down switches, or replace just the individual switches with the fancy new ones.
On a related note, can I put an auto switch in to replace the rear window switch in the console too? I roll it down with the key fob a lot, and it would be nice to have an auto up I could hit as soon as I get the key in the ignition. It would also help differentiate the ECT and rear window switches.
Old 09-17-2014, 11:36 PM
wyoming9's Avatar
Red face
If you have the EWD`s from what ever years your working on can solder and re pin plugs .
I can`t stress having the EWD`s enough !!
You should be able to figure it all out.
Don`t plan on it being plug and play Toyota liked to change connectors and wire colors between the years.
Old 09-18-2014, 10:10 AM
TheDurk's Avatar
Post deleted by author.
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
colinmil
07-06-2015 04:03 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: Master window switch swap questions
