Major sway issues after lifting 99 Prerunner
I had an Icon 2.5" lift put in with add a leaf and bilstein 5100's. The truck sway is huge now and is very hard to control, to the point of it being dangerous if you hit a pot hole at high speeds.
I don't know much about this truck but what can be done to fix this? Basically what parts would I need? Everything else is pretty much stock except the steering bushing. Tires are only 31 with stock rims. Another question, can I go to 33's on this ride or will I get wheel rub issues? It's the 99 2wd PreRunner with the off road package, not even sure what that is.
Any suggestions would be very much appreciated.
Umm.. then how would I lift the ass end off the ground?
because it's a 99 2wd 4runner.......................DUH.......the only 4runner's to EVER come from the factory with leaf springs were the 1st gens from 1984-1989
and you wouldn't have replace the coils with leaf springs if you dont even know what the offroad package is..lmao..
wow...lmfao..i made a TOTAL mistake in reading that title..hahahahahahahaha..i thought you said 4runner hahahahahahahahaha..wow....it's kinda late sorry hahahah
weeelllll in that case make sure all of your sway bar connections are still connected..ya never can tell when one will pop loose..
again..sorry about the confusion..i fully feel like a complete dumbass now..hahaha
Ok, I found this hellwig for the rear: http://www.streetperformance.com/par...4146-7620.html
What about the front? Anyone out there with experience on this?
Icon coilovers are stiffer than stock springs, so I don't know how it is so sloppy that you're almost losing control...make sure you're stock sway bar is connected in the front, that's the end of it really. if you want to put a sway bar in the rear go for it, but the leaf springs are stiff enough to not need one.
if you magically got coils in the rear as camo stated, yea then get the hellwig .
The hellwig is for the rear with leafs. They ubolt on.
Do prerunners come with front sway bars? Are all the tacoma people out trick-or-treating? All i'm getting is 4runner guys confusing me here :>
Yotatech is known primarily for 4runners, ttora.com has a prerunner section you can post in if you want to get even more specific.
I had an '01 tacoma for 4 years, just cause I have a 4runner now doesn't mean I don't know what i'm talking about. Yes, prerunners all had swaybars. Plus, 4runners and Tacomas have essentially the same front suspension.
