Lug Nut Bolt Stripped - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 06-22-2003, 01:39 PM   #1 (permalink)
metal22lica's Avatar
Send a message via AIM to metal22lica
ok guys..i asked this before but here it goes again. ihow to i get the lug nut off since the bolt is stripped. i turn the lug nut and the bolt turns with it. or any advice on where i can take it to get it fixed? i dont want to get a flat and be screwed. plus im about to buy some coils...
__________________
SOLD??? Never
1990 Automatic V6 4WD SR5 4Runner
Mods: Downey 1.5 HDs, Aisin Hubs, CD, CB with a 4' Firestik, Husky Liners, Maglite Mod, 2nd Gen Airbox Mod, K&N filter and a Smittybilt Brush Guard with 4 lights.
Next: Rims? Shocks? Exhaust?
PICS
-Corey
metal22lica is offline
Old 06-22-2003, 01:47 PM   #2 (permalink)
GV27's Avatar
Well, if you can keep turning the nut and the bolt will come out, then just pull it on out and replace it w/ a new stud. If not, most any decent mechanic should be able to help out.
C
GV27 is offline
Old 06-22-2003, 04:13 PM   #3 (permalink)
Staff
Yoda's Avatar
IIRC the studs are driven in from the back and are held by small splines (to prevent spinning). Might need to use a nut splitter or cold chisel to break the nut. Good luck, I hope the hub isn't stipped out and its only a bad stud.
__________________
David
TLCA 14788
71 Landcruiser FJ-40 TBI 327, TH-350, Warn 8000, disk axle swap.
76 Landcruiser FJ-40 project/parts (haven't decided)
Yoda is offline
Old 06-22-2003, 04:41 PM   #4 (permalink)
keisur's Avatar
I used a ball pien hammer to pound it out. I screwed an old lug nut on to it about half way, then hit it 3 good times and the stud pops out, you could just hit the stud itself since you won't be reusing it. then I took the new one, pulled it in as far by hand as I could, put 4 big thick washers on {enough to make sure the stud can go into the lug nut when it is spun on. threaded the old lug nut on and used my impact wrench to torque the lug nut and pull the saration of the lug studs into the axle.
hope that helps, just did it 2 weeks ago when I replaced the outer axle seals, I popped all the studs out so I could replace the oil soaked gasket under that sheet metal backing that the studs clamp down on, on the inside of the flange. so let me know if you need more info. I could actually do a little write-up with pics since I have all the spare parts sitting in the garage.
EDIT
OOPs, just finished reading your thread, the other guys said pretty good stuff on how to get the nut off. you could take all the other lug nuts off and tap those studs out and drive around until the last stud breaks and the wheel falls off, Just kidding of course, sorry.
__________________
Front: 4.88's w/ ARB Locker
Rear: 4.88's w/ ARB Locker
Lift: Suspension - F: Sway-A-Way Coilovers; R: OME Coils/Shocks
Body - 2" HDPE Pucks w/ higher strength bolts
Recovery: TJM T15 Bull Bumper w/ Warn M8000 Winch
Lighting: Lightforce Striker 170's
Multimedia: Kenwood DNX5120 DVD/GPS/USB/iPod/SAT
Sound: Focal 165A1 Component Front w/ Focal 130CA1 Rear
Infiniti Kappa Perfect 10.1 Sub
500W RMS amp for fronts and rears; 500W RMS amp for sub
Power: Optima Blue Top
1400 Watt Power Inverter
keisur is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Tokico top nut stripped off seanz0rz 95.5-2004 Tacomas & 96-2002 4Runners 40 04-27-2007 08:39 PM
02 sensor install.... stripped nut hill 86-95 Trucks & 4Runners 5 02-22-2006 10:14 AM
Fuel filter nut stripped Citykid 95.5-2004 Tacomas & 96-2002 4Runners 8 06-13-2005 09:05 PM
stripped lug nut??? metal22lica 95.5-2004 Tacomas & 96-2002 4Runners 10 03-10-2003 02:56 PM
2009 InternetBrands, Inc.
