Loose Stock Radio Antenna
Old 05-30-2003, 07:23 AM
hipchek117
Guest
Posts: n/a
Went through a quick car wash the other day and half way through I saw my antenna leaning at a 45 degree angle towards the cab. Freaked me out! I thought that it had bent in half, but after the wash was done I jet into a spot and inspected it. The rubber mount had loosened up allowing the antenna to swivel about 45 degrees both forward and backward. Now just driving on the freeway makes it lean over. What is the easiest way to tighten this up? Would it be advantageous to swap it out for a little more flexible one while I'am at it or just tighten it up call it good?
Old 05-30-2003, 09:01 AM
Denk's Avatar
Theres a good write up on how to replace the power antenna with a whip in the tech section. maybe that'll give ya an idea.
Old 05-30-2003, 02:21 PM
hipchek117
Guest
Posts: n/a
alright thanks
mussy01
12-13-2016 08:20 PM
theking11863
03-19-2016 09:36 PM
Team420
12-30-2015 01:31 PM
PNWrider
10-30-2015 08:14 AM
TDonkey
07-26-2015 10:14 AM
Quick Reply: Loose Stock Radio Antenna
