A little help with 97 SR5 and Axle Housing
Old 04-07-2008, 01:47 PM
Kilmer's Avatar
Originally Posted by 111db
Need to find a new shop. Sounds like the fixed the result but not the problem. Ask your mom if the green "4wd" light was on the entire time... the one that shows 4 wheels/axles.
Also, just so you know, what you're referring to as FD is more commonly referred to as "gear ratio". IIRC "final drive" actually takes into consideration transmission and xfer case ratios as well.
The green light went on and off as she engaged/disengaged the mechanism, but I disconnected the front drive shaft and you can still hear grinding, indicative of the front pumpkin still being engaged. I'll be more certain next weekend when I pull the front out. Are the axles just pop from the axle housing out (I haven't looked yet) and there is a clip that holds it in place inside the CV?
Sorry, I come from FWD so to me it's all a FD I'll call it xfer case ratio ...
Old 04-12-2008, 10:06 AM
Kilmer's Avatar
Bought a new front rear end/axle housing with 3.90 xfer ratio...and got the vacuum locking mechanism that I will replace also...not bad for 300 bux from the local yard, should be here Monday...so next weekend I'll attempt to install...see how it goes
Old 04-12-2008, 10:26 AM
Dare44's Avatar
good luck
Old 05-27-2008, 05:23 AM
Kilmer's Avatar
Originally Posted by Dare44
good luck
Thanks! Luck wasn't needed. It was actually so much easier then I thought it would be. I don't know why Toyota charges 8hrs to do this. I got it done in like 3hrs total. The only issue, is that I re-used the seals, and the passenger side seal is leaking. I don't want to drive it like this. What's the easiest place to get these? I called all the local PepBoys etc and non of them carry anything for this axle housing. Should I just call the dealer or is there a trusted online site that I can order from?
Old 05-27-2008, 05:49 AM
  #25
dirtoyboy's Avatar
Dealer OEM...the axle seals should really be replaced anytime the shafts are pulled...seals are cheap....new brakes aint
Old 05-27-2008, 07:46 AM
  #26
BajaRunner's Avatar
I thought the axle housings were all the same regardless of gear ratio?
3 year old post.. Hmmm
Old 05-27-2008, 08:04 AM
  #27
dirtoyboy's Avatar
I dont think the OP has a clue what he was talking about anyways...wtf is a "FD" final drive? nobody uses that terminology
Old 05-27-2008, 10:51 AM
  #28
Kilmer's Avatar
I called around and nobody sells the axle housing seals for this car. Napa, advanced etc etc...What do new brakes have to do with my axles and seals? If anything I'd run out of gear lube in the xfer case.
They can be, for all I know. I am not a 4runner guru.
I don't know a thing about these 4runners, nor 4wd for that matter. I've never driven 4wd cars until I got this thing. Yes, FD is final drive. Since, I am not use to these, I am not as familiar with the terminology. Like there are gear, transfer case & axle ratios from what I found out by replacing this housing.
Old 05-28-2008, 10:00 AM
  #29
Kilmer's Avatar
If anyone cares the seals are ~14 a piece. I can get part numbers as necessary. Only 1 is leaking, so for now I will only replace just that one. It's easy to do. Remove the tie rod and swing the axle out of the housing. 'Press' in the bearing with a block of wood and re-install the housing.
Old 06-02-2008, 08:39 AM
  #30
Kilmer's Avatar
The block of wood method didnt work because of how the seal is set up. I did have some 2.5 inch piping laying around. A slight tap-aroo and now she's as good as new! This whole process was much easier then I anticipated.
Flying91
45
04-11-2024 04:39 PM
the1998sr5
15
07-14-2020 08:35 PM
coreyedwards7611
01-16-2016 06:38 PM
deepmarsh
08-06-2015 03:44 AM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
Quick Reply: A little help with 97 SR5 and Axle Housing
