Leaky valve covers
Leaky valve covers
I'm sure this has been posted before, but here it goes again.
I've got a 96 with a 3.4 and 190+k miles on her. The valve covers had been leaking in the rear so last night I checked the bolts on the valve covers. All of the lower bolts were so loose I could tighten them with my fingers. I snugged them all down, so hopefully that will solve my leak. Just wanted to say check those bolts before they.........
Make sure you torque them properly, not just crank them down. If you overtighten you will deform the gasket and possibly the valve cover itself, which will lead to additional leakage.
From the 1997 3.4 FSM Valve Cover bolt torque: 53 In/Lbs
^^^^ Very True! I just snugged mine down, do not overtighten them or it will be worse that before you started.
......and that would be lbs/in, which 54 seems almost too tight IMO, I probably only went to around 20 lb/inch.
I have no idea why they would loosen up except that they are not "torqued" down to begin with and after 10 years and 170,000 miles there is a lot of vibration and heat/cold cycles. Just one of those things I guess.
At 190K miles and 11 to 12 years of age, those gaskets are hard and have shrunk. They should be replaced. Tightening the cover bolts will only slow down the oil leaks, not eliminate them.
Thanks for the reminder. I've got 223K and suspect a leak on the pass. side. I can tighten mine now in the cold and replace them in the spring when Reno thaws out.
Same with the 3.0L. Drips on the exhaust manifold and smokes up pretty good.
A lot harder to do on the 3.0 since the intake manifold is in the way of the passenger side cover!
he's gone
7
12-03-2019 07:08 AM
09-04-2015 09:27 AM
