Late Model Parts List - Certainly We Can Do Better !!! - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 04-12-2004, 09:23 PM   #1 (permalink)
sschaefer3's Avatar
Come on boys show me the LOVE !!!
Toyota 3rd Gen Part numbers:
Upper ball rubber boot: 43324-39015
Rear Diff, Tranny & T-case low profile drain plug w/magnet: 90341-18021
Gasket for above drain plug: 90430-18008
Outer Tie Rod - Right: 45046-39335
Outer Tie Rod - Left: 45047-39215
Toyota Bolts for shackle hangers: 91642-81235
Manual Tranny, Transfer Case Shift Knob: 36303-35140-CO
Sequoia Transfer Case knob, Used for Marlin Cralwer front case :36303-34030
1999, 4WD, V6, 16" wheel, front coil, left: 48131-35350
1999, 4WD, V6, 16" wheel, front coil, right: 48131-35400
Outter dust seal front axle shaft: 90304-80002
Front shock, Rubber Isolator Ring: 48609-35010
Front shock, Upper Retainer: 90948-02161
Extended rear breather nipple: 90404-51319
Extended rear breather valve: 90930-03136
Tacoma Manual Hub, Gasket Free Wheel: 43531-60010
Tacoma Manual Hub, Gasket Front Axle: 43422-60060
Tacoma Manual Hub, Cone Washer: 42323-60010
Tacoma Manual Hub, Hub Body Nut: 90170-08036
Tacoma Manual Hub, Hub Body Washer: 90201-08042
Tacoma Manual Hub, Cover Bolt with Washer: 91641-80616
Tacoma Manual Hub, Open center Spindle: 43502-04030
Tacoma Manual Hub, Open center Spindle Nut: 43521-35010
Tacoma Manual Hub, Sealed Bearing: 90369-54001
Tacoma Manual Hub, Hub Stud: 90080-11282
1st Crossmember, Left Side Bracket: 51026-35020
1st Crossmember, Right Side Bracket: 51025-35020
4WD Center Mount/Manual Tranny: 12371-07020
Base Model Antenna, whip, black: 86309-AA040
Base Model Antenna Mounting Base: 86300-35090
Clutch Pedal Bushing: 90389-05017
__________________________________________________ _____
Off-Road Solutions:
Axle shaft, 4Runner manual hub kit: ORS-4RAX001
Outter CV joint manual hub kit: ORS-TCV001
Revtek:
Aluminum top spacers: TOE-2
Studs: STD-6
Phone: 1-877-LIFT-TOY (543-8869)
ARB:
Old Man Emu, rear 3rd Gen coil trim packer: OME80PF10
Blue line "trail" repair splice/coupler: ARB170206
Energy Suspension:
Steering rack poly bushings: 8.10101G
Dynomax:
Super Turbo Hemi, 2.25" offset: 17747
Show Your Yotatech Pride !!!
__________________
Steve Schaefer
WWW.SonoranSteel.Com
Suspension Lift Kits * Rock Sliders * Straight Axle Conversions * 4Runner/FJC Rubicon Express Lower Links * Accessories * Daystar Products Dealer * TJM Bull Bar Dealer * Deaver Leaf Spring Dealer * Tokico & Bilstein Shock Dealer * ViAir Dealer * Total Chaos Dealer * TOYTEC Dealer * and like everyone else a Trail Gear Dealer
sschaefer3 is offline
Old 04-12-2004, 09:30 PM   #2 (permalink)
sschaefer3's Avatar
Toyota 8" diff electric locker:
Complete V6 Electric locking 3rd member:
- 4.56 ratio -> :41110-3D010
- 4.30 ratio -> :41110-3D080
- 4.10 ratio -> :41110-3D030
New locker diff. gasket: 42181-60050
Longer diff. studs 111mm (2 required): 90116-08330
Diff. Lock ECU: 89533-35070
Diff. Wiring Harness: 82127-35100
RR DIFF LOCK switch: 84725-35010
__________________
Steve Schaefer
Old 04-13-2004, 06:47 AM   #3 (permalink)
sschaefer3's Avatar
1998 4Runner
ASCO/Aisin Seiki Clutch Master Cylinder: 31410-35310 (I3000-55036) ( www.thepartsbin.com )
ASCO/Aisin Seiki Clutch Slave Cylinder: 31470-35120 (I3010-54125) ( www.thepartsbin.com )
__________________
Steve Schaefer
Old 04-13-2004, 07:01 AM   #4 (permalink)
sschaefer3's Avatar
Sway-A-Way:
Upper poly seat: 6191 or 1619 (can't tell which side was up when numbered.)
__________________
Steve Schaefer
Old 04-13-2004, 07:03 AM   #5 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
Talking This is all I got handy...
I hope you feel the LOVE!
Fender Well Grommets - Part No. 90189-06028
I've used all sorts of nuts/bolts etc. but haven't kept track of part no.s...
waskillywabbit is offline
Old 04-13-2004, 07:23 AM   #6 (permalink)
sschaefer3's Avatar
I fell the LOVE, keep it coming !!!
1999-2002 Headlights:
Right: 81110-35320
Left: 81150-35300
1999-2000 Grill (chrome): 53111-35460
1999-2000 Emblem: 75311-35090
Anyone know the part numbers to put 2001-2002 tail lights on a 1996-2000?
__________________
Steve Schaefer
Old 04-13-2004, 07:41 AM   #7 (permalink)
Send a message via Yahoo to bamachem
Stuff for a scooped hood and a sunfire red grill - Only thing missing is the part number for the hood, but that one is very easy to find...
In my opinion, you can delete items 7, 8, and 9 and never know the difference...
bamachem is offline
Old 04-13-2004, 10:07 AM   #8 (permalink)
Jonathan's Avatar
Send a message via AIM to Jonathan
What exactly are parts 7,8,9?
__________________
1996 Black 4Runner
V6 5 speed 4X4| Retrofitted E-Locker| SAW's| LC coils and Doetschtech shocks| ATS arms | 285 Goodyear MTR's|TJM T-15 With Warn M8000|Retrofitted Toyota Hood Scoop| Stubbs Sliders|Bushwacker Extend-A-Fender Flares| Extended rear diff breather| Uniden 510XL CB w/ 4 Ft. Firestik II Antenna|Dynomax Super Turbo Muffler|Black headlights and corners| More to come...
2007 VW GTI 6 Speed
Jonathan is offline
Old 04-13-2004, 11:08 AM   #9 (permalink)
Send a message via AIM to CLin9383
Right: 81110-35320
Left: 81150-35300
passenger side 8155035240
driver side 8156035200
__________________
1996 Limited
CLin9383 is offline
Old 04-13-2004, 11:17 AM   #10 (permalink)
sschaefer3's Avatar
I have heard you need a small wireing harness as well? Any truth to this?
__________________
Steve Schaefer
Old 04-13-2004, 01:32 PM   #11 (permalink)
not when i put mine in. took out the old ones, plugged in the new ones..took all of 20 minutes. no problems since..
8155535210 passenger tail wire harness
8155535240 driver tail wire harness
i did not get these when i installed mine. i am not sure if they are neccessary but like i said, i just took the old ones off and plugged in the new ones..somone else chime in here??
__________________
1996 Limited
CLin9383 is offline
Old 04-13-2004, 02:08 PM   #12 (permalink)
AznSky's Avatar
Send a message via AIM to AznSky
Warn Receiver Shackle Bracket - p/n 29312
Parts for driver side "Oh sh$t" handle
Screw - 90159-60254
Grip Assy - 74610-16010-E3
Plug, Assi - 74617-16010-E7
Plug, Brea - 90930-03136
Union - 90404-51319
Driver side front axle boot - 04438-35060
Cobra 18WX ST II CB radio (fits perfectly in lower DIN) - p/n 480-315-P-001
Windshield wiper insert - 85214-YZZD4 , 85214-YZZD3
__________________
Rob
AznSky is offline
Old 04-13-2004, 02:29 PM   #13 (permalink)
RTdawgs's Avatar
Toyota Part# 90119-10816, Front bumper frame bolt w/ washer (these mount your TJM to frame)
__________________
Ryan
New: 2008 4Runner Sport. Mild, not wild.
Old: 2000 4Runner 305s, Locker, TJM, Warn, Skids, Sliders, SC
RTdawgs is offline
Old 04-13-2004, 06:37 PM   #14 (permalink)
sschaefer3's Avatar
All great numbers to have, lets see some more LOVE !!! I need some love tonight, for the next 3 hours I get to dance with an ARC Stick welder..........
Max Green told me a year ago learn to stick weld first, I am. It’s not easy. I have Oxy-Acetylene down as well as the popular MIG.
Post some Part numbers while I light myself on fire, again......
__________________
Steve Schaefer
Old 04-13-2004, 09:56 PM   #15 (permalink)
TechWrench's Avatar
Steve; A little off topic, but where did you get the avatar pic. It brings back some OLD memories for me. I was drinking Schaefer about when you were born (illegally of course) 0 . But some time after I went in the service, they moved the brewery and it was never the same again.
__________________
TechWrench
If it ain't broke,
fix it till it is.
'03 SR5 V6, Titanium, 275/70-16 REVO's on '02 OEM alloys for winter. Anti-chipmunk mod for fresh air intake.
TechWrench is offline
Old 04-19-2004, 07:16 PM   #16 (permalink)
sschaefer3's Avatar
3rd Gen Rear Exhaust Doughnut: 17566-35030
__________________
Steve Schaefer
Old 04-19-2004, 07:18 PM   #17 (permalink)
sschaefer3's Avatar
Quote:
Ok, back in 1994 we went to Cancun Mexico and met a couple from New York state. Turns out the guy loved Schaefer Beer. He sent me that coster that he recived years before as well as a Schaefer t-shirt. I scanned it back in 1996 and dug the scan back out for the Avitar.
__________________
Steve Schaefer
Old 04-28-2004, 08:02 PM   #18 (permalink)
sschaefer3's Avatar
1999 4WD 4Runner Rear Coils (Higher)(both sides): 48231-35210
__________________
Steve Schaefer
Old 04-28-2004, 08:07 PM   #19 (permalink)
sschaefer3's Avatar
Come on boys lest see some LOVE ???
__________________
Steve Schaefer
Old 04-28-2004, 09:28 PM   #20 (permalink)
Jason B's Avatar
Send a message via AIM to Jason B Send a message via Yahoo to Jason B
sschaefer, what the heck are you doing? Did I miss something? Are you bulding a beast?
These part numbers with get your 01 tails/harnesses.
81550-35240 - Right
81560-35200 - Left
When you order them from the dealer you get a new wiring harness and new bulbs with them. The new bulbs fit the new smaller sockets. The bulbs are also more realible. The old ones used to burn out quick, pre 01 owners will vouch for this.
Install write-up with pics of harness, etc. found here:
http://www.toyotaoffroad.net/jnburtman/Pictures.html
__________________
Jason B
4Runner Limited
For Toyota/SUV Accessories, please visit www.burtmanindustries.com
My 4Runner Website
Email: jason@burtmanindustries.com
Live Chat/Message Board: http://get.to/jasonforum
AOL/AIM: JNB133
Jason B is offline
Old 05-05-2004, 06:09 AM   #21 (permalink)
sschaefer3's Avatar
3rd Gen and Tacoma Trasfercase shift base gasket: 36345-35050
3rd Gen and Tacoma Trasfercase shift lever boot, small, rubber, lower: 33555-35190
__________________
Steve Schaefer
Old 05-26-2004, 02:26 PM   #22 (permalink)
sschaefer3's Avatar
Toyota Seal Packing 1281 (Orange Silicone used on tranny and transfer case) FIPG
00295-01281
__________________
Steve Schaefer
Old 05-26-2004, 03:38 PM   #23 (permalink)
AUJWE
Guest
Posts: n/a
DOWNEY
Pre-Charger - wrap for K&N filter on FIPK: 18038
__________________________________________________ _______________
TOYOTA
3rd Gen roof rack rail - Outer Skid Strip: 00278-96042
Fuel Sender Gauge Assembly - from TSB: 832011
*includes: *fuel send assy - gage: 83320-35590
*fuel sub-assy - tube: 77203-35461
*fuel suction - gasket: 77169-60010
BILSTEIN
3rd gen rear shocks: BE5-2451
Old 06-05-2004, 09:34 AM   #24 (permalink)
RTdawgs's Avatar
Lower Strut mounting bolt, 4WD 4Runner: 90105-14104
__________________
Ryan
RTdawgs is offline
Old 07-08-2004, 10:24 PM   #25 (permalink)
RobT2k's Avatar
I found the Toyota starter rebuild kit packages I got when I fixed mine. Starter problems pop up here from time to time, this is almost always the solution.
Repair service kit: 28226-54340
Starter kit:28226-72010
Got 'em both for under $20 shipped.
This thread, or a link to it should be in the tech/writeup section permanently.
Hopefully new people will get to see this now and keep it going.
__________________
'99 3.4L Limited *Trail pics*
RobT2k is offline
Tags
30306c, 4335039085, 4549039375, 4561936010, 6980189122, 9021442030, 9024908018, 9031141007, arm, ball, bearing, idler, joint, part, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Shopping for a late model 4Runner jodynich 95.5-2004 Tacomas & 96-2002 4Runners 13 11-30-2005 04:11 PM
Late model VW experiences? SEAN_at_TLT Off Topic Talk 7 10-08-2005 12:11 AM
which late model toyotas have manual hubs? DevinSixtySeven Offroad Tech 6 08-19-2004 12:21 PM
sway bar disconnects for late model taco 4x4taco Offroad Tech 3 03-28-2004 07:26 PM
New Late Model IFS Lift/Arms/Stuff Flygtenstein Offroad Tech 3 02-07-2004 06:52 AM
2009 InternetBrands, Inc.
