intermitant blower
intermitant blower
I have a 99 taco an the blower has finally stopped completely. Not suddenly though. over the last year it would be fickle and sometimes run without hesitation. other times it would only run after a while of driving, and usuallu always after up to speed on the freeway, like it needed airflow to jump it. now it is just dead. Also, it seemed that it was running slower even at the High speed setting.
However, the motor runs with direct current. the resister tested good and now back testing the control center. I seem to have found a lack of continuity in the A/C switch ON posistion, though dont know why that would keep it from runing if the A/C worked with the blower would run??
Am I on the right track? going in for the blower speed switch continutuy test, its deep in there. Or could it still be the motor and it only was turning do to the direct current amps??
kawazx636
10-06-2021 03:03 PM
gyroscope7
7
09-27-2015 08:39 PM
