Interior Spare Tire Mount
#42
Banned - User requested
I would prefer a telescoping mount
With people running MTs, ATs, 15"-16"-17" wheels, and differnt brand tires...i just don't see how a stationary mount will work for everyone.
as you can see in the bend of the tube, and where the wheel mounts, it doesnt matter if you have an AT or MT tire.
#44
when I first read this post last week it made me rethink my original idea of a
swing out carrier. there's a trail of the power lines that i ride my bike on i've seen a burned out blazer and it had a interior tire carrier so saturday morn took my tools and the dog (with orange vest on since its hunting season)
retrieved it. put it on today, removed a body mount bolt, bolted down the tire carrier to it. still neet to fab a support for the front bolt, but tire fits perfect and only moves alittle so won't be wheeling until the support is made.
will post pics monday or tuesday
Woody oh and free after about an hours work
#45
its not the size or type of tire, as said earlier, a 285 is about the biggest you can fit standing up, and the size of the wheel doesnt matter, we all will have the same bolt pattern, so thats not an issue.
If theres a 1/2"~ difference in tire size (common with different brands/types) hows it going work for everyone if it's stationary? The tire/spare weight needs to be supported by the floor. If it was built for a 33.1" tire, then a 32.9" tire isn't going to be touching the floor....or reverse that sceario and the bigger tire wont fit. I wouldn't trust a wheel-well to support the entire weight of a big spare. Also, i think wheel size does matter because tire sizes become slighty different.
#48
the blazer mount i got has a 3.5 or 4" slot running vertical and fits a 1/2 " carrage bolt. only need one bolt, and would fit many different tire sizes.
#49
If a 285 is the biggest tire that can fit vertically...then as long as it's not bigger; which it can't be and still be standing up, then you're okay.
If x is the tire you have then as long as x < 285 you're fine...which it has to be.
You could be mounting a spare tire from your girlfriends Corolla and still be fine, the mount will be strong enough, atleast I would hope, to hold a tire off the ground.
I also agree that the mount may not be as strong if mounted on the wheel-well.
It will all come down to what happens in Ric's rig.
As Ric said, check with Jed and see what the $$ difference is. I think either way I would still like a stationary one, maybe he could produce both if we had enough interest in the product.
Thanks for the hard word Ric, still can't wait to hear what the final ruling is.
Fink
Fink
#50
#51
lol, well...let's just see what Jed says about the whole telescoping thing...I would still prefer mine to be stationary...I won't be going to 35's ANYTIME soon.
Fink
Fink
#52
I am sure that without the tube in the way you are perfectly correct.
Bumpers??????????????????????????????????????????? ???????????
#53
I'm only putting forth a concern/discussion.
Thats exactly what i don't want. Tire should be on the floor.
Only if you believe the fender well is strong enough to support a heavy spare.
Yeah, a 265 or smaller i might trust but think about how much a MT 285 tire with a steel rim weighs!
Thats exactly my point.
IMHO, If you off road, suspending a big and heavy spare from the fender well is only asking for trouble. Soon as you have a nice side "jolt" to either side, that sheet metal will bow/bend. Only way to make it strong enough would be to add a brace/plate under the wheel well that the bolts would go through....even then i don't think it would be strong enough to keep suspended for off-road.
The tire in this picture is on the floor, how it should be....
http://www.trail-gear.com/bbs/fj80/10.jpg
With a roll bar, it's not an issue for two reasons....1) the spare sits on the floor and 2) the roll bar is attached at four points on both sides of the truck...
http://i12.photobucket.com/albums/a2...gowithtire.jpg
I can think of 3 or 4 different designs that would make this "new" Spare Tire Mount fully adjustable to fit tires from a 31" to a 35" so that no matter what size you have, it will always be rested ON the floor. And it wouldn't rattle.
Is anyone with me on this?
#54
Absolutely!
It needs to be on the floor. The way I see it the mount (roll bar or other) is there to steady the tire. If the floor is supporting the weight then all you need a mount to do is hold it still which is a lot easier to do than suspend it.
It seems like it would be difficult to make a bracket the adjusts to the exact size of a rim and tire combo without actually measuring it. They could made it telescoping but without holes, then you drill it for your specific use when you are installing it in your rig. You will have to drill holes in the floor anyway. Mock it all up with the tire and drill it. Bolt it with some quality nyloc hardware and be done with it.
#55
I can stand my 35's vertically in the back and have plans on making a tire mount to hold the wheel on the left side....
#56
update:
ok guys, I just got done visiting with Oleg, for those that dont him, he is very respected in the toyota community, a great body shop, and does awesome custom work.
Anyways, I was talking to him also about the tire carrier, he said as pictured, it wouldnt be a good idea, the 4runner wheel wells are alot thinner than the Land Cruisers, and that with 4wheeling, it over time would probley tear up the wheel well.
He could make a support bar, that would be mounted to the pillars, just below the window, or to the roof, that (in his opinion) would be the best for long term, but that would cost more.
He did say that he would draw up some plans, and let me know what he thinks would work good for the 4runners, and be durable.
I can/will still talk to Jed, and see what his opinions are.
#58
"just" got off the phone with jed, and after talking to him, and Oleg, we will diffenatly need to support the tire mount, as the 4Runner wheel well is not as thick as the Land Cruiser, I was hoping this would be something simple and easy to get done, lol what was I thinking, lol.
Anyways, Jed and i was talking about making it simular to whats been posted, but will try to run a support bar to the pillar, where the seat belt attaches, and this will bring up the cost, and i have to take my rig down to co. springs, so that we can plan out some options. so if any of you have any ideas or plans and want to share them, that would be awesome.
Jed did say that he has some ideas, as we have talked about this for about a year now for my rig.
we will keep you all posted.
#59
Which seat belt mount are you talking about? The ones for the rear seats or up on the actual pillar? Would this require cutting a hole in the pillar? If so that really stinks...I was hoping to keep it as stock as possible inside.
Either way, can't wait to see what you guys draw up.
Keep us posted man!
Fink
Keep us posted man!
Fink
#60
Im not sure exactly which one Jed is talking about,
you and me both.. as soon as i can get down there, Ill have a better idea of what he is thinking.
