Interior light problem, HVAC question
Last night i was installing my Blue LED's i recieved from autolumination. after i installed a couple in the middle console area i noticed my interior lights no longer worked accept for the dome lights, key ring light, and my cd deck. thought i might have blow a fuse but all of them check out ok from my first look at them...any advice would be great....also anybody ever swap out the turn knob HVAC to the digital HVAC that are in the limited Runners? im interested to see how it worked out for ya. thanks for the help.
if this helps anybody my PRND12 light isn't working along with glove compartment, ashtray, HVAC, and gauge lights....im totally stumped as the fuses inside the truck look fine, Ive yet to check the engine fuses thoroughly
did they work before u installed the lights? have u checked the bulbs to see if they are blown? or that u have voltage? might be a bad switch. mine had bad grounds and i just ran all new grounds to the lights then looking for the short.
Thanks Justin. i went through my fuses one last time in the engine compartment and found a blown fuse. all works now now would anybody know anything about switching out from the manual climate control to the digital?
same yrs? if so i dont see why it wouldnt work, but look for the wiring diagrams and that will tell u more and if not try it is all i can say and see what happens
yes same year, im assuming the wiring diagrams are the same. im just worried about the temp readers inside and outside the truck.m assuming there arnt installed since my runner isnt a limited. anybody familiar with this?
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
