| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Install Tips for Viper 550 ESP on 3rd Gen???
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#2 (permalink) |
I work next to a Circuit City, and those guys install those alarms all day long, but they have help from tech sheets (cheat sheets) to match up wiring and all that good stuff. If you want I can probably get those cheat sheets for you, it makes thing a whole lot easier from what I observed. Let me know.
#3 (permalink) |
You know I have one of those fancy remotes with the screen on it. I had it installed at Tweeter about 11 months ago, and I broke the remote from dropping it over and over. They replaced it free under their lifetime warranty. Which more then paid for the cost of install.
Just one thing to consider before doing it yourself. But if you do, do it yourself, its a rather straightforward instal. I watched the guy as he did mine. You can also get DEI on the phone to help you with the wires matching up, they have great customer service. good luck
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards. <-- the artist formerly known as sdastg1 |
#4 (permalink) |
I would recommend these 2 sites: the12volt.com and carsound.com
#5 (permalink) | |
Quote:
If you could get me one of those cheat sheets that would help a ton!!!!! I will have a manual and have looked at it online but it is usually quite generic. If I could have the alarm wiring direct matched to the truck's wiring harness it would be a cake walk! I would really apprecaite the help. sdastg1, I would love to have them do it but I got such a deal on the alarm (only $130 new with a parts warranty!!!!) So unless I can bring the shop my own alarm to put in it wouldn't be worth it. Plus if anything goes wrong they will blame the part.....sounds like a headache to me.....not worth the hassle. I am pretty good with electronics but the "cheat sheets" would help the process considerably and allow me to get my bearings much quicker. I will try and take some pics to help others in the future. Keep the comments comming!.....helps a ton!
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 12-07-2003 at 06:26 PM. |
#6 (permalink) |
I'll hit the fellas at Circuit up tomorow for the tech sheets, your rig is a 96, I looked at your pics but can't tell if it's an auto or stick, let me know, they just installed the very same alarm for my 97 runner and I like it alot, they even added the windows up and down for a little bling bling . You have access to a fax? let me know.
#7 (permalink) |
Hate to but in, but the above mentioned sites have most all vehicles tech. sheets on file, plus you can ask experienced installers for advice as you install the alarm. They are a great help for any skill level. LOTS of alarm info/tips. I recently installed a Clifford AG4 remote start alarm for my first ever install, and know what a help these 2 sites can be.
#8 (permalink) |
3rd Gen.X,
Yes, I definately appreciate the help/links...I will certainly take a look and I do appreciate the help. If saigon1965 can get me the sheet(s) then that will just save me some searching and give me a good head start before I get into it. I will certainly take a look at the sites before I start the job. Thanks again!
__________________
#9 (permalink) |
Hey saigon1965,
Check your PM if you haven't already.
__________________
#10 (permalink) |
Send me all the "cheat sheets" you guys have.
Thx!
__________________
#11 (permalink) |
Was anyone able to get any of the sheets?
I sent out a bunch of PMs.
__________________
#12 (permalink) | |
Quote:
__________________
Why is it we don't have enough time to do things right, but we have so much time to do things over? Quote: For all you helmetless bad boys, try the following experiment: Tie your hands behind your back, stand up straight and then fall forward onto your forehead. When you regain consciousness, consider what happens at 35 miles per hour while you just make a "quick run to the store". |
#13 (permalink) |
Dude, tried faxing you today but some "French" broad's answering machine came on , her message was in french too, your girlfriend? maybe wrong fax number?
#14 (permalink) |
I got a PDF that might help
I managed to get hold of a PDF that may do what your looking for so drop me a PM and I'll shot it out to you. Forgot to mention the info I got is for a 96
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2| Last edited by WT; 12-10-2003 at 10:29 AM. |
#15 (permalink) |
hey MTL, you're gonna have a write-up after this right?
__________________
Rob |
#16 (permalink) |
I'll take a bunch of pics when i do it and post the tech sheets I have collected thus far. Thanks to all who have sent me stuff for this.
I can't wait to put it in because everyone that has installed it seems to love the alarm (I really want the remote start part). I have a Viper C70 (that's what is on the brain unit anyway.....but I can't find an install manual for it on DEI's website!?.....so it may be a part number for another model of alarm) installed right now (it was done professionally before I got the truck) so i hope that will make my life a bit easier. Anyone know where I can get an install manual for the viper C70? Is the C70 even an alarm model or is it a part number for another alarm?
__________________
#17 (permalink) |
Yeah I got the Viper 790XV sitting in a box still i got last month, Waiting on a buddy to do the hook up he said its pretty strait forward on the 4Runner but hes done this before in his past job so I trust him to do it right for me. Now thats its gotten cold out I wish I had the remote start from a 1/4mile away with confimation
Also I sent you email with the file. Keep us update on how it all works out
__________________
96 4Runner SR5 SC | 3" Revtek Front/OME 891 Rear,Diff/Panhard Drop|AirLift bags|285/75/R16 Nitto Terra Grappler|Eaqle 121 w/TRD Logo|Bilsteins|Cross-Drilled PS w/PF Pads|Silver Reverse Gauges|Custom Grill|Catch-All Floor Mats|Sylvania SilverStar|Weather Tech Visors|Clear Corner/Fronts|Alpine MP3/WMA/CD|99+Headlight/Console Mod|K&N FIPK W/Drycharger|Optima Redtop|Trans-Cooler|Remote Start|PICS|PICS2| |
#18 (permalink) |
Well I just got the unit last night and started the install today. Too bad I picked the coldest damn day of the year to try and finish the job. What a royal pain in the butt to run all the wires (really not that bad but the cold weather and nasty windchill really makes it all quite miserable
). Word of advice to all who will attempt this install.......put in a remote starter BEFORE you need it. That aside I should have some pics up by tomorrow.
__________________
#19 (permalink) |
Mine stopped working a few weeks ago. Like you push the buttons and nothing would happen, wouldn't let me start the car with the key ... nothing. After about an hour I just reached under the dash and ripped the whole damn thing. Started right up and drove over to tweeter, and demanded the number to DEI and Tweeter corporate. The guy told his store manager and he came over and told me that their getting a shipment of the new Viper alarms in on the 5th of January. and that he would rewire the entire alarm and no charge, and continue my life time warranty. He even offered his personal car so that I wouldn't be without a car for the day.
oh good luck with the install.
__________________
#20 (permalink) |
i was looking for exactly the same thing, make sure you select the right year. they've got wiring sheets for many cars on that site also. hope this helps...
http://www.bulldogsecurity.com/wires/toy4run00-01.htm http://www.bulldogsecurity.com/wires/toy4run99.htm http://www.bulldogsecurity.com/wires/4runner96-98.htm Last edited by gn86r; 01-01-2004 at 05:24 PM. |
#21 (permalink) |
Can someone post a wiring diagram for the ECU, I am having trouble locating a tach wire that is easy to get to. I tried to route it through the firewall and it worked well but I could not close the diagnostic port after. I would like to get a wire off of the ECU that works so if anyone knows the color offhand I am willing to try. Thanks for the help!
I am so darn close to finishing I can taste it.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 01-02-2004 at 02:16 PM. |
#22 (permalink) |
I finally got it all to work!!!!!!!!!!!!!!!!!!!!!!
:xmas3: ![]() I will try to write something up so others do't have to go through the same 2 day battle I did. This install was not for the faint at heart and when you are done you are pretty much able to hotwire your own vehicle blindfolded. It was a bit tougher for me cause I looked for other pics or info about someone else doing something similar on a 4runner but it seems like everyone just takes it to an electronics place and has them do it. If you are squeemish about ripping the entire dash apart, then by all means have someone else do it for ya. Routing the wires was a major PITA but once they were all run it really came out nice and the rest seemed to fly. The cold was miserable but I felt pretty good when it all worked. Also this website rocks for alarm install info: http://www.the12volt.com/installbay/...pics.asp?FID=3 Several times it got me out of hot water!
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! Last edited by MTL_4runner; 01-02-2004 at 02:35 PM. |
#23 (permalink) |
Here are the pics I promised!!!!!
Alarm as it came out of the box ![]() The old alarm install was a mess Putting in the remote starter part (relays galore!) Look at all the soldering fun I had Here is a look just before I buttoned it up I wish I could have taken more pics but I froze my a$$ off putting it in so that was the best i could do under the circumstances. There are some more pics at webshots so take a look here if you want to see everything I took: http://community.webshots.com/album/109253034GvuWek If anyone needs help figuring out their install give me a holler. Thanks to all who helped with the wiring diagrams and cheat sheets!
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Viper alarm install need some pointers | paxil4x4 | General Electrical & Lighting Related Topics | 1 | 01-14-2007 11:18 AM |
| How much for a Viper 550 ESP installed? | Lance | Alarm Systems | 3 | 12-06-2006 06:29 AM |
| clutch install tips. | DN1911 | 86-95 Trucks & 4Runners | 2 | 07-10-2006 06:54 PM |
| Tech Write-Up for Viper alarm install | MTL_4runner | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-09-2004 06:49 AM |
| New Toys for Xmas, need install tips | My99 | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 12-25-2003 09:08 PM |
