Idler Arm change
Idler Arm change
My 'runner has been pulling to the right, even after two alignments, so I took it to a different shop, and they said my Idler arm is worn out. (Love that $99 lifetime alignment)
I found one at Autozone for $72, ($180 quote from the shop) and plan on changing it Monday after work. I'll rent their tie-rod tool for $15, because I think I'll need that to seperate it from the linkage, anything else?
I've changed ball joints, tie rods, and rack&pinions before, so it shouldn't be that hard.
Thanks in advance
Thanks in advance
Check out these links:
http://www.4x4wire.com/toyota/maintenance/idler/
http://www.off-road.com/toyota/tech/idler/
Sam
Sam
Should've researched more before ordering.
Has onyone on the board rebuilt their idler arm? If so, should I order the parts and fix it myself, or replace the whole thing?
I'm at 128K miles, BTW.
WellsR
12
07-31-2015 03:27 PM
kirkrunner
07-27-2015 07:59 PM
FS[SouthCent]: TX Third Gen UCA and LCA low miles Taco
KyleT
07-21-2015 07:54 PM
